- 18 Feb 2007
- London
Check the app, it'll tell you what it think it heard
and you can even listen to what it heard
Mine has done it a couple of times now, but then I realise I'm listening to a tech podcast and they just mentioned Alexa...
The TV can set it off, and the people on the TV doesn't necessarily need to say Alexa, at least not that it sounds like Alexa to me.
Ok thanks.
By the way do these things get software/fix updates automatically?
) - You can teach it to perform activities, I simply say "Alexa, turn on the TV" and that's it. It triggers my TV action.
