Amazon Fire TV
13 May 2010
Hoping someone can answer this...
Is there any way that I can stop my TV auto-selecting the Fire TV HDMI input when it is turned on? It's fine when you want to use it, but when you don't , is annoying.
Any solutions appreciated, guess it could just be the way the TV is setup?
8 Jun 2007
On mine only HDMI 1 does that,maybe change to another HDMI port if you can.
Kol
Kol
Man of Honour
8 Jan 2003
Ashby-de-la-Zouch
Guys, just a gentle reminder as with the Kodi thread, any mentions of addons will be removed and risk the thread being nuked. Please no more mentions of questionable sources. I don't want the minority spoiling it for the majority.
10 Aug 2006
I've given up using my Fire TV for the main TV as it's slow and annoying, got a android box for Kodi and Plex which works much better and loads videos quicker and can do 4K video.
All for less than the Fire TV cost me.
24 Oct 2002
Bucks and Edinburgh
As said, why are you turning it on if you dont want to use it? Fire TV goes to sleep if you are not using it so the TV wont auto select it unless you press the remote to wake it up
13 Sep 2005
I have a similar issue where I boot up my PS4 which wakes my Sony TV and it switches to the PS4 AV channel. Then the Fire TV goes NOPE and takes over and switches to that.
I just press the PS button on the pad again to switch back but it is a minor irritation.
11 Jan 2005
Birmingham
what android box / specs did you get? Looking to replace the fire stick, and was looking for a fire tv but im edging more and more to an android box.
13 May 2010
Why are you turning it on if you don't want to use it?
I didn't write that post very well. I meant that when i turn my TV on, even if the Fire is Idle/Sleep Mode, It still defaults to that input. It's just inconvenient and wondered if it was something i could change. Not really the end of the world...
8 Oct 2005
Herefordshire (U.K.)
Reading what other posters have already said, it looks as if some TV's connect by default to whichever device is plugged into the HDMI 1 port, so if this is not something which can be changed in "Setup" you might have to try plugging it in to one of the other HDMI ports.
20 Oct 2002
London
Ah, yes I see. What Montala said sounds right. I don't have an AV amp so my FireTV is direct into one of my HDMI inputs; and it doesn't default to it.
10 Aug 2006
So for the slow reply, I only went basic, and bought the Bqeel M9C Pro Android Tv Box 6.0 which is a 1gb model, but much quicker than the firestick imo.
16 Jan 2004
Workgroup
An Android box with an S905/S905X chipset will be very quick with Kodi, much quicker than a Firestick. There is limitations with Android & Kodi though if you use things like 24Hz and/or DTS passthrough, however if losing Android isnt a major issue you can install LibreELEC and everything works great.
You can technically dual boot too, with LibreELEC on an SD card, although you lose a little bit of speed due to the read/write performance of the SD card vs NAND (Maybe not be massive if the onboard NAND isnt that that fast on your device, but that varies from device to device.)
P.S. I have a Nexbox A95X with 2GB ram and its been flawless.
12 May 2012
Im going to buy the new nvidia shield tv for streaming kodi netflix amazon & android. Hopefully that will be a lot faster than my fire tv box, & on a + note I will be able to do a bit of gaming also.
15 Nov 2003
Marlow
Let me know what the Amazon support is like. eg: If you get anything other than stereo sound etc!
