What sort of temps are you getting at 5?
I stopped prime at 92, reached it REALLY fast. Going to delid and try again in a week or two
Don't use prime.
How odd, guess it depends what your cooling is but with corsair H100 fans on silent maxed out at approximately 80 degrees after prolonged testing.
Don't use prime.
I have a Xpower monoblock and a custom loop all round (GPU inc) 4.7Ghz hitting a max of 96 whilst gaming :\.
This is bad. Something is wrong.
delidding will fix it
No, its not a case of delidding. Prime is not recommended any more by intel. Certain instruction sets cause voltage spikes that can result in really high temps. Use Realbench or Aida64.
why should you have to potentially ruin a cpu to `fix it` - this is Intel`s fault
read where he says it hits 96c in a game... nothing to do with prime.
i know. they cheaped out with poopy thermal paste again
Missed that, I was referring to the his other post about getting 92 Degrees in prime. Something is wrong there. I am pretty certain that poopy thermal paste would not cause such a high temp, especially with watercooling. Drop it to stock and see if you still get high temps, if yes, then it may be the thermal compound but if not try checking in the BIOS for your voltage, LLC etc in case something is not correct.
Really? Do a bit of research. It started with Haswell. Consumer Intel CPUs (SKT2011 do not seem to be adversely effected by this) Prime 95 causes the CPU to pull way too much voltage at times causing spikes. Prime 95 puts an unrealistic load on these CPUS that will not be achievable with gaming/normal use/rendering.
