I made a good post in the 2.0 thread about where to get supplies etc. from:Scales - http://www.amazon.co.uk/dp/B00ME8VI34
PG/VG and Nic all from Darkstar Vapour - http://www.darkstarvapour.co.uk/
Concentrates are a personal choice, I mostly use FlavourArt, Capella and TFA (The Flavour Apprentice) - http://vapable.com/ / http://thee-cigshop.co.uk/ / http://www.flavourart.co.uk/. Just take note that some contain known 'nasty' ingredients; Acetoin, Acetyl Propionyl and potentially Diacetyl. For the record FlavourArt (FA) use NONE of these ingredients. Stay away from Flavor West concentrates!!
Bottles - https://www.ibottles.co.uk/products/...tubby-tip.html
I'd probably pick up 2 of these to hold your PG and VG. 250ml ones are 45p each - choose the 24mm Natural Nozzle and Captive Cap option.
Recipes: http://www.lediypourlesnuls.com/ - http://vapingunderground.com/forums/...id-recipes.50/ // depends what type of flavour liquid you're after, but I'd probably look at making some fruit ones to start off with, they require very little steeping time (usually shake & vape!).
Recipe calculator: http://e-liquid-recipes.com/create
That should be everything to get you set up mate, if you need any help gimme a shout.
Thanks
