- 23 Mar 2011
looks heavily influenced by true detective S1. Which is great !
Not the first time I've heard this, excite!
Must say (for me at least) the move to first person has been a resounding success. I find it so much more atmospheric and immersive.
I found a bug
Maybe Crapcom will release a patch to fix it..
and
21:9 support
Yes, working well here.
This tells me your monitor isn't calibrated correctly
The top one is just crushing blacks, you loosing a lot of detail in the shadows.
It would be nice to play a 2017 release at 3440 x 1440p on release day.
Others Devs manage it.![]()
there should be an old skool mode that when you die you have to go back to a tape recorder save and you can only save at tape recoders when you get tapes!
Quiet liking this so far, playing at 1440p with 1.2 multi in settings everything maxed and getting 80+ fps on my overclocked Fury X.
Just got outside the house now, will play more later on.
Apparently there is something like this in the NG+, except it's VHS tapes and you can only save when you have one in your possession and they're one use only.
Just finished it took me just under 10 hours on Easy.
Not a bad RE game at all way better than RE6 but still nowhere near as good as RE4.
This new RE game engine is very powerful thoughTowards the end of the game you get a brief ingame engine cutscene in full daylight & can see all the lighting FX in play for a few seconds without the dull filters they use most of the time to present a misty atmosphere....it looks stunning detail & lighting FX wise. Shame they used a little too much atmospheric mist in places to dull the levels down a lot. One of the later levels goes very blurry for a while not sure if its intentional or not you will know it when you see it!
Also watched the end credits. Capcom did the PC version themselves all inhouse & also did all the QA inhouse no-one else is mentioned (QLoc did not appear to be involved like previous PC ports). Did not notice a single bug or crash at all so looks like Capcom did a very good job here on the QA.
The only negative is the game is a little too short overall its not that large at all due to the backtracking it takes a while to playthru but there are not that many locations (some change at different times to different appearances).
I'm running a Fury X too with pretty much everything maxed but whilst I'm also getting high FPS rates I get the occasional stutter when turning round some corners - is that happening for you? Have you maxed everything? Not tried different anti ailising or anything?
