- 25 Jun 2008
- Bonnie Scotland...and sometimes Denmark!
I can't get my Hub 2 and 3rd gen lights working as they should.
I can turn the light on\off or dim\bright ok. But the Hue scenes won't work.
Like I try "Alexa, Savanna sunset in living room" I get "sorry I can't find a device with that name"
I've factory reset everything and started again with no luck. Can anyone advise me?
I must admit that I have had no problems with this. Best advice I can give is to make sure Alexa can see all the different scenes in the app. For example every scene almost acts like a new device. We have 8 bulbs in the house but it shows as about 64 different devices in the app, "Energise in Ceiling Light", "Sunset in Office" etc.
Then you should be able to tell Alexa to set one specific light or a whole room to a scene. Definitely works for us.
