Has anyone claimed to know what the difference is between the supposed R3, R5, R7 vanilla and pro versions?
Just read this
https://www.cpchardware.com/intel-prepare-la-riposte-a-ryzen/
Interesting if any truth to it both for AMD and Intel, will say though if I just bought a Kaby I5 I'd be super unhappy or an i7
Wouldn't you be peeved tho if you just bought a Kaby i7 or i5 and they release a higher clocked version? And ontop of that release an i5 with HT?
Worrying news about the And 4c chips tho not clocking even as high as the 8c ones
Hmm.... Intel increasing TDP Again with KB to run yet higher clocks still out of the box, interesting.
This flies in the face of Intel (upto this point) going for power efficiency, now its starting to look like Intel 4 core is using more power than AMD's upcoming 8 core, wouldn't that be embarrassing.
Well if Intel is offering a 4C/8T K series CPU at £240,that means the AMD equivalent will either have to be cheaper or have more cores.
It will lack any GPU so it will have to cheaper anyway otherwise AMD are worse than Intel.
Just read this
Jeez, don't like the sound of that.That is interesting - if the lower core RyZen chips are really nerfed 8/16 core versions that cannot sustain the frequencies and also have dud cores it could mean that while the first release 4 and 6 core Zen might be limited on frequency and not compete so well against the higher frequency Intel when the process matures and they are creating 4 and 6 core chips on purpose out of 'A' grade silicon there could be very significant speed bumps.
This is the most in-depth coverage of the present leak information I've seen:
http://wccftech.com/amd-ryzen-am4-processor-family-leak-r7-1800x-flagship/
You might have seen this list supposedly showing a full lineup of Ryzen CPU names. As much as I would like to say that the list was fake, there is nothing that would suggest otherwise. In fact, I can already tell you that Ryzen CPUs are already being detected with their ‘real’ names.
So far we have seen two Ryzen 7 CPUs which are 1800X and 1700X. The only difference from the leak is the R7 moniker is being shown as Ryzen 7. I’m not sure why ‘eight-core processor’ is not shown as ‘octa-core’ though. Of course, we will keep you updated once more CPUs show their full, and hopefully final, names.
I don't think we're going to see a return of the era when Athlon II X2s could be unlocked to Phenom II X4s (IIRC). It seems wasteful to just make a batch of 8-core chips and disable cores to make 4-core and 6-core variants but maybe it is cheaper overall, who knows.That is interesting - if the lower core RyZen chips are really nerfed 8/16 core versions that cannot sustain the frequencies and also have dud cores it could mean that while the first release 4 and 6 core Zen might be limited on frequency and not compete so well against the higher frequency Intel when the process matures and they are creating 4 and 6 core chips on purpose out of 'A' grade silicon there could be very significant speed bumps.
None of AMD's chip's at CES ran as low as 3Ghz, it was 3.4Ghz+ and 3.6Ghz+.
So given that ^^^^ The slide citing 3Ghz is lower than the slowest chip at CES, thats what i said and its what i meant.
Its like you are on a different plane of reasoning to what's written in black and white.
Its not at all complicated nor does it have alternative meaning, it is just that the slowest chip at CES was running a minimum of 3.4Ghz and the slide stated a minimum of 3Ghz.... 3Ghz is a lower number than 3.4Ghz.
https://videocardz.com/65708/intel-preparing-core-i7-7740k-a-response-to-amd-ryzen-7-1800x
Videocardz confirmed all above Ryzen names are fake, it seemed WhyCry already saw the final retail Ryzen CPUs real name.
Doubful if leaked Ryzen RZ 780 is the real name.
There was only 1 chip at CES. They didn't have the SKU's there or to show. I think that is what you are missing. You stated that the information at CES was wrong which is not true. We always knew there would be lower end chips and that the ones they had was the higher end one. It was given as info during an interview at CES (with a nod and wink confirmation based on question).
I have no different planet just well aware of what was shown and nothing there contradicted what was shown. What you read into and perceived though is very different to the actual info provided at CES.
People here jumped in stating that if it's only 3.6GHz that couldn't possibly be the top end chip, they all wanted to believe that we would see 5.0GHz chips which just isn't going to happen. At least not any time soon.
