Think you need to watch the presentation to understand where their confusion originates from....
Again, the way he's interpreting it, if that slide means that EVERY Zen has the same specs, then EVERY Zen released is a 8 core 16 thread... that interpretation flies in the face of any logic, every fact known about what is coming and makes no sense.
There is also 20+ years of cpu architecture launches that says when talking about a chip the flagship is the 'peak' of an architecture and what is spoken about in these cases every single time.
When Nvidia first spoke about Fermi, it was about the biggest Fermi, when Nvidia first spoke about Pascal, it was about the biggest Pascal, when AMD first spoke about Vega, it was about biggest Vega(specs, bandwidth, etc).
This is a 100% industry standard. Go on Qualcomm's site (as I have recently) and it lists only the max clock speed achievable for that chip ... yet dozens of phones come with lower clocks. When Micron talked about gddr5x, 14Gbps was talked about only... yet it launched with 10Gbps. When HBM2 was talked about, 2Gbps was mentioned, yet the first chips available are 1.6Gbps.
In talking about new types of memory, gpus, cpus, ssds or literally anything in the industry, the 'biggest', or top version, or fastest possible designed for version is what is talked about, because that is what the technology is capable of, there will always be smaller, lower binned, salvaged or derivative versions available.
