- 30 Aug 2009
- one nation under sony
Depleted uranium is used as armour piercing ammo. You use armour piercing on tanks and fortified emplacements. Not to casually shoot people from small arms.
Edit: which of course you know because you read the link you posted.
Edit 2: and that still doesn't explain why DU is worse than chemical bombs. Surely both are bad?
US fired depleted uranium at civilian areas in 2003 Iraq war, report finds
not all chemicals are the same tho, DU effects on people from the second gulf war are still around, do you think chlorine bombs will affect people in the same time duration
no I don't support isis or the moderate jihadists that you and robocod defendAnswer the question I asked.
Your source only says some people believe something. Doesn't mean it's true. Millions of children believe in Santa. Is he therefore real?
We are so, so dumb.
