Interesting some newer info on another site showing that the ryzen cpus are only faster or as fast as intel in the 2 bench leaks so far. In actual gaming and video conpression tests ryzen is a lot slower by over 20%
Please provide a link so we can have a read?Interesting some newer info on another site showing that the ryzen cpus are only faster or as fast as intel in the 2 bench leaks so far. In actual gaming and video conpression tests ryzen is a lot slower by over 20%
More info. please. Some are dropping a fair amount of money on Ryzen.Interesting some newer info on another site showing that the ryzen cpus are only faster or as fast as intel in the 2 bench leaks so far. In actual gaming and video conpression tests ryzen is a lot slower by over 20%
Yet,some also forgot the CPC leak magically and these same people ignored them when the same lot leaked the Athlon 64 results months before it was launched.
CPC is a well known French print magazine so there is no reason they would risk their reputation on making up benchmarks.
They showed Haswell to BW-E level IPC in their leak,and almost all the leaks have shown that level of performance.
That is on a 8C/16T sample with buggy SMT,and clockspeeds between 3.1GHZ to 3.3GHZ using a Fury X,so now think of an 8C/16T CPU at 3.6GHZ to 4.1GHZ,and now you can see where it might land.
Before Bulldozer launched there were leaks showing IPC might have regressed and nobody wanted to believe it since it seemed unlikely it would be the case,but they were accurate.
Nobody is expecting AMD to match or beat Intel IPC or clockspeeds when overclocked,but it does not matter as the pricing is aggressive.
Edit!!
Even at Haswell level IPC for gaming,its still going to be solid overall.
Ties in with the April release that has been rumoredRyzen 5 confirmed for Q2...
