Any idea when we can expect low profile [non-ECC] DDR4 to arrive? Never been a fan of RAM with gaudy heat spreaders.
There will be nothing. Lowest profile stuff we do is Kingston Fury and Corsair Vengeance LPX.
can you confirm this pair is compatible please the 370 taichi and 3000mhz Corsair Vengeance LPX, will i need to change any settings or will it be good to go out of the box.
thankyou for any and all help
Yeah I'm starting to see that, hadn't really looked into DDR4 but it seems not a single manufacturer is making non-ECC VLP kits yetThere will be nothing.
assuming i dont know how to do any of what u just said (and i dont) should i just go for 2666 to get it up and running with no tinkering?It will work but you will need to setup the memory manual in the BIOS, so set it at 3000MHz, set basic cas timings and set voltage to 1.35v. See how it goes, if it does not run drop to 2400MHz and work up from there, though the Asrock's are performing very well indeed. They are like the wolf in sheeps clothing.![]()
Hi there
Just to help educate a little.
Ryzen is compatible with all current DDR4 memory and officially supports upto 3600MHz.
However the sweet spot is 2400-2666MHz, this speed will work with all mainboards including cheaper options.
3000MHz and above will ONLY work at such frequencies in the flagship mainboards like Asus Crosshair for example and even then the maximum stable speed we achieve with a lot of messing around was 3200MHz, which really makes 3000MHz the maximum speed we advise.
Of course you could buy 3200 or even 3600 kit now, and just run it at a lower frequency with more aggressive CAS Timings and as BIOS updates come out then you might be able to achieve higher frequency.
As such we recommend 2400-3000MHz kits for use with Ryzen, faster kits will work just fine but you might have to run them below the rated speed and just set the memory timings more aggressive.![]()
flagship motherboard eh?
What about this one, it will do up too 3200 mhz ram mhz speed.
https://www.overclockers.co.uk/giga...ocket-am4-ddr4-atx-motherboard-mb-557-gi.html
Right, i want the best possible speed Memory, so whats the consensus on which motherboard will support that? And is there much difference between the B and X models? im going single card, so leaning towards B, with the thoughts that the cPU's dont OC very well if at all, so im prob going 1800X straight up to get the best possible speed / Cores.
Problem i have is which Motherboard is going to offer the best Ram support, i want a minimum of 3000mhz, on a B350 if possible?
Yes, its called AMP. Might need to dig in the bios as you say but I imagine thats where the OC profiles for the higher end boards are coming from.Do the AMD boards/bios support the auto-configuration of memory - XMP ??
Been a long time since I've been in the AMD fold and I cannot remember if it will work - e.g. its largely a BIOS function but may need some support from the chipset too but I would sort of expect it to work (and I've not found any downloadable manuals for x370 boards yet).
M.
Motherboard manufacturers always make claims, but maxing RAM frequency on all platforms never comes easy.
Elite 32GB (2x16GB) DDR4 PC4-19200C16 2400MHz Dual Channel Kit - Black
Gibbo dude, l have 2 sets of this, l am assuming this will be ok for:
GA-AB350-Gaming 3 AMD B350 (Socket AM4) DDR4 ATX Motherboard
Or
MSI
B350M Gaming Pro AMD B350 (Socket AM4) DDR4 Micro ATX Motherboard
Trying to keep the cost down so it slides under the wife's radar![]()
Or
MSI
You've done the pre-orders a massive favour
Prob most info buyers will get till the 2nd hehe
*cough* Gaming 3, should be good up to 2667hz in thoery, but easier to play it safe![]()
 ta muchly. lol just noticed the MSI has only 2 dimm slots, doh!The two 32GB kits should work fine assuming you want to keep to those speeds.
