What sort of overclocks were produced on a B350 mobo?
Does the B350 even overclock ?
Don't think I was clear with my reply. I agree the 1800X is binned to attain the quoted max clocks but I don't think it necessarily correlates that it will clock better. High-end 1080s are similar.Gibbo just stated what he had gotten a 1700 to, Nothing to do with what humbug commented on quite rightly that often the best binned overclock to the highest level
But we just tested a 1700, it hit 4.0GHz stable in everything, but ONLY in the Crosshair mainboard, the lower-end boards it was hovering around 3.80GHz as the VRM's were cooking with extra voltage. It however was maxing around 4050MHz, so I'd say 1700 can do 3.9-4.1GHz, of course the 1800X will probably do 4.1-4.3 as no doubt better binned, but if your clocking the motherboard has a big impact on the overclock and so far Asus Crosshair and Asrock Taichi seem the best two.
I say it how it is, Intel is still selling and always will, we have no exposure on Intel.![]()
4.1-4.3 isn't great overclock for a top bin.
Sorry Humbug, I had to go to bed!Across 15 or so games the lower clocked 6 core 6850K was faster than the higher clocked 4 core 7700K
Think he was refering to the 1700 with the extra volts.Its actually no Overclock at all, the 1800X boosts to 4Ghz, some commentary say with XFR its boosting to 4.1Ghz, so 4.1Ghz is zero OC, 4.3 is, well, 4%, how can it already be running right on the limit at 95 watts? Gibbo and 8Pack say its VRM throttling, at 95 watts????? the FX-9590 i had was pulling 300 Watts stressed and even that never had VRM throttling.
Very strange.
Those results are quite close, around 5%, getting close to margin of error.
Also I guess they are all at stock, no overclocking so that could reduce the gap.
As you can see above 6 is diminishing returns. As I've said the 6c could be the gem. More cores is definitely something for the future, I just feel at the moment a balanced system is preferable. A 4c/8t + decent graphics card is better than an 8c/16t + a relatively weak graphics card.
Gibbo said the 1800X may only clock to 4.1 - 4.3Ghz ^^^^^^^ it also doesn't explain why the VRMs are apparently throttling at 95 watts +, that makes no sense.
So you get higher performance with 6 lower clocked cores than with 4 higher clocked cores, and that's an average across 15 game a lot of which are older low threaded games, so a 6 or 8 core chip at the same IPC and price as an 4 core chip can be a better option for gaming, do you not agree?
As I said it's very close. Was it at stock clocks?
oh and i think i'm right in saying on average the 6850K has more OC headroom than the 7700K
They are all at stock clocks, would you qualify it only if the 4 core chip was overclocked but the 6 core not?
The 6850K is 27% ahead of the 4770K and 6% ahead of the 7700K across 15 games, the 6850K is faster than both of them, so if the 6850K is the same price or less than the 7700K its the better gaming chip, there is no getting away from that.
Here you goIt doesn't makes sense to me, A 7700k has a high stock clock while a 6850 doesn't so the 7700 should do better with a cross section of games, Can I have a link to that review so I can read up on it please![]()
Oh come on....... you're not that naive? is that a joke? surely you know Mhz is not the only thing that matters?
One of the German reviewers i think it is, i didn't post it...
I'm under the impression that the majority of games still only use one or two cores so it'll depend on the games tested, therefore I was interested in seeing how the individual games in the test scaled, why that would make me naive is beyond me but don't worry I found the review myself thanks.
That has not been true for a while and its increasingly more and more untrue.
4.7 - 85% do this (this is why we offer retail un-opened boxes guaranteed to this)
4.8 - 70% do this
5.0 - 30% do this
5.1 - 10% do this
5.2 - under 3% do this
To put it in different terms, one and a half, two and two and a half times as many cores nets an average of 4.8 to 6.4 fps is pretty much negligible.
