Really? Wow so I expect them to be around the £150 mark then
Lower than an i3? Intriguing.Really? Wow so I expect them to be around the £150 mark then
Aye was posted few pages ago here
We shall see. As I said if the 1800X overclocks to 4.4-4.5Ghz going to grab one without second thought next week.
Also I will do the same if it overclocks to 4.7Ghz at 4 cores, with the rest deactivated.
If honest enough about it, nobody here is going to be in that user group. Outside the realms of stability testing, it's limited to a handful of professional application. Even then, it's questionable if you'd be looking at either consumer platform for this. It's taken users (and Intel) 3 years to adapt to the fact that when overclocking, the current some of these tests can pull limits the user. We've seen Handbrake, and that's as good a real world AVX test as any, especially in terms of power draw too.
The nail on the head is really that the performance is evidently competitive in most areas, and even the memory side should improve with firmware and microcode. Including I'd imagine, what is happening to some of the boards. How often really in the history of all things relevant, has VRM failure been due to design? It's almost always inherently firmware related. So short answer is in my opinion, give it 2 to 3 months, and you'll hopefully have a solid product, and an 8 core option that will make people question what they're really paying for elsewhere.
It just goes to show just how good the aggressive pricing on these is, any word on the 16xx Prices? Given they are the equivalent of the i5's (aren't they?)
thanks for that info, it seems from your link the sm961 is the good buy?you should just swap the M.2 SSD to a 850 samsung 500GB, if you dont get a high capacity 960.
the performance of the low capacity 256GB sux, you can check the review.
Tom's hardware
I'm fairly sold on the performance and one of three motherboards depending on reviews but can't decide between a top end air cooler, h100i v2 or the h115i having never gone aio before![]()
But this should not be a surprise to anyone keeping up with the news.
AMD has competitive IPC with Intel now so to beat the 7700K stock speed of 4.2/4.5 with the 1800X which is 3.6/4.0 it's not a huge overclock required to reach the same single threaded performance.
But its not a great cpu to pick a comparison with, 7700K can overclock a lot.
It's the 6, 8 and 10 core intel CPUs which take the real hits.
What are you talking about? The 7700K can't really 'overclock a lot', it's close to it's overclock limit with its stock boost frequency of 4.5Ghz out of the box. It's average overclock seems to be around 4.8-4.9Ghz, that's only 300-400Mhz more frequency making it a poor overclocker albeit the stock frequency is so high (because Intel had to do something to make people want to buy these Skylake+ CPUs)
On the other hand, the Broadwell-E's that you point out are better overclockers, even the 10-core 6950X has a turbo frequency of 3.5Ghz and can overclock to around 4.2-4.3Ghz, which is 700-800Mhz more frequency from overclocking.
Thats not what I saidAnd where do you get a lower end i7 for £150?
+1 thats a first for me, agreeing totally with anything you have said, well done though, i totally agree 100%
lol, yeah I thought you might like that one. Wouldn't get used to it. It's not really a matter of opinion that AVX512 has limited application, it's just a fact. As for the rest; I'll have to follow up with something hard hitting and cynical shortly
An incorrect choice of words, the 7700K can overclock higher, the launch party overclock session managed just over 5GHz at -200 degrees on the 1800x.
The point being that the intel quad cores will have the frequency edge when frequency matters hence 7700k not being a great chip to claim as a competitor since the octa cores are prioritising threads not frequency.
I can't see the 1800x coming out as a particularly good choice for a gaming cpu at £490 vs the 7700k for example.
Hold on a sec. The Intel B-E 8-10 cores cannot do more than 5.2Ghz on LN2 either. The H-E 5960X can do 5.8Ghz but it's performance is beaten by the 5.2Ghz 1800X
And yes the 6700/7700K can do 7Ghz on LN2 but ONLY WITH 2 CORES!!!!!!! The rest are turned off.
