Yes, I'm not dissing on AIOs, they perform just fine for the most part, but some people do have high expectations simply because they have liquid in them, which they believe is assured to offer a far superior cooling solution, when it factually does not. It's quite obvious many people buy them for this reason. The aesthetics argument is by far the strongest, and as mentioned, where high profile RAM or case clearance height is air cooler prohibitive.
On the faffing point though... I fitted a D15 recently and it was the easiest cooler I've ever fitted, bar none! The BeQuiet Dark Rock cooler is still a PITA though, so they aren't all so easy. Weight on the mobo isn't really an issue with modern boards, unless you're moving your PC around a lot. Noise levels can actually be higher with an AIO due to the pump noise... it's product specific and also the case can factor in, but a friend of mine has a Corsair AIO and regrets buying it because of the noise... he had a quieter system before with his BeQuiet Dark Rock Pro 3 cooler, and his temps are the same lol!
For Ryzen, no one NEEDS an AIO to achieve high performance from their CPU... that's the myth that needs to be busted here. There's a stronger argument for a custom loop if ultimate performance is desired (and you are happy to pay for it), but for a healthy overclock a top end air cooler will do the job perfectly fine, and then some!
Agree
	 ), the L2 cache of Zen literally doubles performance, L3 has 50% higher read, 3x the copy and marginally behind on write. L1 is a little slower on Zen. Read though... wow. My quad channel 2400Mhz is getting 46.9GB/s, Zen with 3200Mhz is beating it. Max theoretical numbers are once again popping up showing AMD smashing to pieces anything Intel has on efficiency. I don't have l2/l3 latency as trial version hides that, L1 read(so read might be great), also memory write/copy are hidden but there is no reason write will be monumentally higher than read, nor is it more important anyway.
