Caporegime
- 18 Sep 2009
- Dormanstown.
If you order now, then that's the date.
Ouch.
For new orders.
Calm down, we've got differing opinions.
And I want an excuse to buy a new system? That's why I'm running a 4770K with a 290x......
If I wanted to keep my CPU, why would I change my socket?
Looks like motherboards are coming up https://www.overclockers.co.uk/asus...am4-ddr4-micro-atx-motherboard-mb-69l-as.html
Just read that review. Just wait till Friday . and expect bios updates to come out fast for all motherboards . vendors rely on reviewers doing the early tests and getting back data to test to get new bios.
Now with amd this hasn't happened . or couldn't.
And to all those that get their chips and boards, hold out a bit as you'll know you'll see good improvements within the first quarter with your systems as bios and chipset updates roll out
Stability and support for new hardware is the norm for BIOS updatesWhen has this ever happened? I can't recall any time that we've had any type of gain from bios updates and chipset drivers.
This rhetoric was used when bulldozer launched, but it doesn't need to be used here.
I should also add that i read through that review, they are using 2133Mhz memory, that is very low, i think some of those game benchmarks would be significantly improved with 3Ghz memory, especially Bioshok infinite which seems to be entirely FP dependant.
True that will make a difference but also remember the Ryzen's IMC is 95%+ efficient compared to 60-70% for intels so even though it might be running 2133Mhz its effective bandwidth will be comparable to an Intel running at 2.6-3Ghz.
I was agreeing with you!I meant the performance improvements.
No amount of deflection changes this:
1.)AM2 Phenom II would work in AM2 and AM2+
3.)AM3 Phenom II would work in AM2,AM2+,AM3 and AM3+
4.)FM2 CPUs would work in FM2 and FM2+
We'll find out shortly when we get "proper" reviews.People seem to be missing, the 7700k it was being tested against had 3200Mhz memory. Now if anyone needs reminding, Zen supports 2666Mhz at stock, that's it's default frequency, this was 533Mhz lower than it should have been. On the other hand 7700k only supports 2400Mhz so it was overclocked by 800Mhz.
Even if it only made a 1% difference, that could mean the 1700x beating the 7700k in 1080p by 1 fps, or increasing those min resolution tests by 10% while reducing Intel's by 10%.
The 'stock' comparison would be Zen @ 2666Mhz and 7700k @ 2400Mhz. Testing 7700k with memory way out of spec and the 1700x with memory WAY under spec is ridiculous, yet Zen was still crazy competitive.
