This review from guru3d is pathetic...who cares about results in low res. In only worth looking full HD difference is 1fps or nothing...and why the hell they are still using this bioshock in their reviews. Who cares how many fps this game has. It's got no relevance with current games. I hope tomorrow reviews will be much better like:Getting spanked in most of them benches. Hype train wobble.
It's not their review...This review from guru3d is pathetic...
I know.... they still posted it and article is on their websiteIt's not their review...
they don't, they underclocked Zen memory by 500Mhz, overclocked Intel memory by 800Mhz and used engineering samples of both chip and motherboard without anywhere near final bios by the sounds of it. Meaning, that is less than the 1700x performance you'd really get, more importantly, 1080p gives identical performance where Bulldozer based chips wouldn't.
CaseKing being naughtyDelidding an Ryzen!
Its Soldered
why don't these guys just ask AMD kindly if they can have one with no HSspanked? are you serious? all bar one the performance is the same, and this with 2133Mhz ram on a Motherboard with an engendering sample BIOS.
Getting a bit too eager to pour scorn on it.
Right......
Power consumption: actually very good, slightly less than the 7700K... this for a CPU with twice as many threads, a complete turn around from AMD, now they are significantly more power efficient than Intel, did you ever think you would see that written in text?
Cinebench, one of Intel's favourites, tho not for much longer i suspect.....
And some games, a mixed bag, not bad, really not bad at all, but also not great....
All in all i think thats really good.....
An official review with an engineering sample? I don't know why they would tamper with the memory though.
Its Soldered
Do we know much more about overclocking on the 1700?
Slight hint here I think.I rate a rock solid 1000MHz+ overclock as a solid overclocking CPU, especially when cooled with just a 120mm AIO.![]()
And
https://forums.overclockers.co.uk/posts/30555341
