Spec me a CCTV System
5 Nov 2010
Hertfordshire
Decent NVR required. I will source and buy the HDD and cameras separately, currently thinking Hikvision, but my Swann system has been great so open to suggestions.
Requirements:
4xPOE connections
Support 4x1080p @24fps
No HDD required
Smart phone app for remote viewing.
There's probably plenty of suggestions here already, but it's a big thread! I will get reading anyway :)
Also, regarding the "Law" and regs etc. Where do I stand with this?
http://imgur.com/a/4VkOh
Basically I cover the front of the house with this view but also the track. This track is technically several people's (long story) but 3 properties have right of access over it (including us as sole access to my property) and it's also a public footpath. Would I ever get a slap on the wrist?
The other two people know and are grateful for me covering the track, but it's the general public, dog walkers and the like.
11 Mar 2005
I've got a 5 cam setup using the Hikvision cameras. I use the DS-7608 - which is the 8 port NVR. Might be worth considering an 8 port just to future proof.
They now do a 4k version - but I would guess that would be overkill??
I had issues with ambient light in our street being rubbish - so had to install some lighting to the front. The picture is crystal clear and I'm running it at max FPS. The NVR itself is really clever and with a bit of fiddling - you can achieve what you want. The alarm inputs / outputs are good and any cameras with sound work seamlessly.
I considered building a PC and using third party software - but to be honest, it just seemed like such a faff.
Samsung do an alternative SRN-873S - but i think price is comparable.
Good luck!
5 Nov 2010
Hertfordshire
Good luck!
Cheers :)
8 Port is overkill, I will start with 3 cameras and maybe install a 4th if required. If i got the DS-7608, is it possible to record 4x 1080p @ 24fps at once?
13 Mar 2017
London
I am planning an entire home rewire and I'll like to plan and install the security system so that everything can go in the wall before plastering etc
I was just wondering if anyone has purchased from cctv systems from hdcctv.co.uk or cctv42.co.uk? Any other home security tips/systems that can be wired and installed at this early stage would be appreciated.
4 Feb 2003
West Midlands
Set up a hikvision DVR and 4 cameras at the weekend for my parents.
Very impressive kit. However...they live in the rural and power goes off once a day. As such resets the IP address and this in turn effects the remote monitoring on the hikvision app. Other than requesting a static IP address from the isp which I can't do as they are not a business customer, what else can be done? I see you can register a hikvision domain name?
11 Oct 2011
UK
www.no-ip.com
Will that not solve it? Or am I missing something?
18 Oct 2002
SX, unfortunately
As Pho says, a UPS would be invaluable for anything like this as power cuts and restores aren't going to do any good to them anyway.
8 Nov 2006
Cheers :)
Im using the 7108, cheaper china model I got off ebay for £120 with english firmware. I have 4 x 1080p recording at 25fps albeit on a motion activation, they are usually all recording at once when it rains hard.
www.no-ip.com
Im using a free no-ip account, you just have to confirm you still want the account every month (they email you) seems to work ok so far :)
11 Oct 2011
UK
Take a look to see if you can enter the login credentials into your router, then this keeps it active and updates it regularly with the latest ip
6 Feb 2004
Norfolk Broads
@LFltecher
that seems like a LOT of cameras
Have you drawn out the positions, FOV and pixel density?
I'm reading this thread and trying to understand how I might go about spec'ing an IP camera CCTV system for myself. I see in your response to LFletcher, you talk about camera positions, field-of-view and pixel density. I have a basic understanding of field-of-view and corresponding lenses, but would you be good enough to expand on the pixel density bit?
31 Oct 2002
Newcastle upon Tyne
I'm trying to understand CCTV systems but it's going to take me a while to read up on the last 60 pages.
While I'm doing that could somebody let me know if this is any good? Is it worth paying the extra for a POE system?
EDIT : is it worth paying a bit more for the 3MP version?
16 Nov 2003
On the pale blue dot
Another newbie popping into this thread. We were recently burgled and we're exposed as there is a shared drive between us and the neighbour which allows people to walk right up to the back garden and hop over the fence. So practical considerations are:
  • I can't put a camera on the side of the house as it will be pointing right into the neighbour's windows, so I am thinking one over the front door and one over the back.
  • We are directly opposite a primary school (about 80 ft away from the front door to the school gate so I imagine DPA is going to cause us some bother. With dome lenses can I move the lens so it only sees as far as our property boundary?
On the technical side I have a Synology disk station with a bunch of WD Reds in it so was thinking:
  • Two IP cameras with PoE (what brand, type?), will need IR.
  • PoE switch or two injectors (probably go switch for future proofing) connected to our BT router.
Am I missing anything? What types of camera should I be looking for?
11 Apr 2004
I'm sure Hikvision have their own DDNS service. A friend at work has just set up some Hikvision kit and by logging into a Hikvision portal (I think it was this one http://www.hik-online.com/auth/login) he was able to access his cameras.
28 Dec 2005
Greenhithe, Kent
This is a similar setup to mine with a camera on the front and back. Yes, you can adjust the position of the lens in a dome camera and you can also mask the picture, i.e. put an electronic black patch over a section of the picture which won't be recorded.
I went with HIKVision cameras as they're pretty good value for money. Synology publish a compatibility list that may be of use when you choose: - https://www.synology.com/en-uk/compatibility/camera
