You speak?
I tried to drag you onto their Discord a while back..
Tanks can be very vulnerable, especially the light flanker. It's great at farming infantry as long as you have an escort. It was speed nerfed since beta though which means that when your brainless team decides 2/3s of the flags are not enough and zerg forward, you'll get pincer-ed by assault class players as you can't keep up. 2 assault players can take you down very quickly and a squad will smash you in seconds.
Suppression is definitely back with vengeance in BF1, but even when you're not suppressed you can find yourself walking up behind an unsuspecting camper, put the barrel of your model 10 hunter shotgun to their head pull the trigger and miss. Then 5 mins later you're storming a bunker and 4 kills in 4 shots.. The longer you stay on a server the better the hit reg seems to get which suggests to me that there are sync issues when you join a server (which reminds me a lot of previous titles). It's no worse than SWBF though..
We communicate telepathically
They got discord now? I thought they were teamspeak for life (got the server address for them), if so, I can finally uninstall teamspeak!
But but but.... the tanks are OP in bf 1!!!! This just shows DICE catering towards the casuals even more. Tanks were fine as they were (at least everything about them except for their damage + splash damage anyway), as you said, team up (and have a team that aren't all snipers...) and they are **** easy to take down but the COD generation like to be able to take down tanks within minutes/seconds all by themselves...
Can't say that I've really ever had any hit reg. issues with battlefront (other than the insane hit box range for the light sabre attacks, a bit like the cavalry's sabre sword in bf 1, although it isn't as bad...
