i didnt the board died. i just use the pc and if it blue screens i go into the bios and change things till it stops blue screening.
Funny...
No I mean what stability tests have you run?
i dont. at all. simple as that.Funny...
i dont really see why you think its funny. i spend 95% of time of the pc pushing it to the point where it crashes. if its been on for more than 10mins its clearly too stable.
http://hwbot.org/user/jumper118/#My_Submissions
link you what exactly? Specs? Its pretty old.Good mate. You use Prime when you have your own range of components and systems!! Can u link me to your systems please??
neverhardly the same as actually using the PC is it?
thats what i like. each peice of hw is like a new game
platform/chipset in the genre of game. 775 and 1366 are the best
neverthats what i like. each peice of hw is like a new game
yes i do have a 24/7 rig for folding with an i5 5675C which is nearly stable. its bsod probably once every 2 or three months. never stress tested it and i dont run f@h on the cpu. i just ran cinebench r15 until it bsod at a set voltage then lower it 100mhz and go with that. i dont use speedstep or any power saving features, so that will decrease the chance of it overvolting itself too much when going from idle to load. if it bluescreens in normal operation as it degrades like my pentium g3258 did running at 1.4v., i just lower the speed as required. the other wya you can do this is have a fixed speed and lower the voltage, but i like to run maximum voltage for the highest speed rather than random speed with the lowest possible voltage.so you overclock for records rather than a pc to use? Thats fine, two different types of overclocking i guess?. People who just benchmark to beat records and others that like to tinker and still have a 100% stable PC... Hence Prime95 or OCCT or Linpack.
I'm a bit confused.
I thought with the 1700 the speed when overclocked past 3.7ghz, the cores are always running at what you set it?
I'm using the Ryzen Tool. At load, my speed is 3.825ghz and at rest Taskmgr shows the CPU lowering to 2.7ghz which is fine my me. I remember someone saying with the 1700 it always has to run constantly at the overclock speed?
1700 @3.825ghz - Stock Cooler - 1.181v
If that is stable at that voltage you have a gem.
Its his hobby and he is entitled to use his PC how he wishes, dont see why you need him to do things he does not find fun.so you overclock for records rather than a pc to use? Thats fine, two different types of overclocking i guess?. People who just benchmark to beat records and others that like to tinker and still have a 100% stable PC... Hence Prime95 or OCCT or Linpack.
They do if you have windows in balanced power modeJust testing now, I'm getting 1623 in Cinebench R15 so it's looking good.
Anyone clear up the situation with the 1700? Do the cores scale back when not under load?
Hahaha I have bloody good cooling if there isMaybe there is?? ^^
