Man of Honour
- 16 Jul 2009
- Edinburgh
Seems good fun, motion controls are a bit annoying though!
Can you turn off the annoying motion controls?
You can turn them off, as I noticed as the server turned off
I take it, it takes a while to get used to? Why is it better? More precision, much like a mouse?
There is no auto aim in Splatoon unlike CoD and other console FPS games as the motion controls are almost as good as a mouse once you get used to it. This means you really suffer when using just the analog stick as you are effectively playing against mice-level players without any auto aim to help you.
Yes I agree they're jarring at first but get past the initial frustration and you will soon be wishing all console FPS used the same control scheme.
The trick is to use the stick for big motions (anything over 45 degrees) and the motion for the finer precision after you turn. I also press y a lot to reset the motion controls to neutral which helps a lot with orientation.
So a lot like Zelda with using the stick to aim mostly, and then motion control for the precision? It makes so much sense on with arrows.
You need to get used to them. They area a thousand times better than using analog sticks.
So after an hour of playing, the game is identical to the previous Splatoon on the Wii U. I'll be getting it and smashing the non-motion players to pieces all over again
Test fires over the weekend:
Saturday, March 25
03:00 to 03:59 GMT
11:00 to 11:59 GMT
19:00 to 19:59 GMT
Sunday, March 26 (change your clocks to BST!)
04:00 to 04:59 BST
12:00 to 12:59 BST
I couldn't get in at all when I tried earlier to download splatoon.Anyone having issues logging into the shop?
What is the switch then? Is it Nintendos next gen system or more like a portable wiiu? Havent had a nintendo system since i got a wii on release.
Exactly, but annoyingly you cannot use the stick at all to move in the y-axis. This takes a little getting used to and requires regular use of pressing y throughout the game to reset your horizon.
I just can't abide them and don't see how they are any better?
Have you ever played an FPS game with a mouse?
It really does, you need to give it a proper go.Of course but I don't think it compares.
