So in game the 7700k still kerb stomps the zen in AOTS by a huge margin, the built in bench is useless then.
Not had the chance to read their review I'm still at work but have they used same settings ram etc?
It seems PCGH used their own test sequence instead of the built-in benchmark:
http://www.pcgameshardware.de/Ryzen...ecials/AMD-AotS-Patch-Test-Benchmark-1224503/
Its a decent improvement,but nowhere as much as in the benchmark though.
	Awful unprofessional benchmark, and being grasped at like the proverbial last straw by the Intel shills.
2400Mhz RAM on Ryzen, pathetic.
The guy is wrong in some places:
"with 2 x 8 GiByte DDR4-2400 RAM (14-13-13-33 2T, Dual-Ranked ) And a Geforce GTX 980 Ti (1,380 / 3,900 MHz). Please note that Ryzen CPUs are greatly benefited from Dual-Ranked Memory (vs. Single-Ranked). "
Single Ranked performs better than Dual Rank. He's also using 2400mhz RAM where 3200mhz would have a significant difference to the performance.
In the comments his explanation is "No, Dual. The channel interleaving helps. Is easy to remember, because dual is more than single."
There is also no mention anywhere of the specs of the other system, only "For comparison, we used a Core i7-7700K."
It would seem to be a very amateur benchmark.
Asus Crosshair 6 Hero (0902-UEFI), MSI Z170 Gaming M7, 2 × 8 GiB DDR4-2400 (14-13-13-33, DR), GF GTX 980 Ti @ 1.390 / 3.900 MHz (378.78 WHQL HQ); Win 10 64 bit
	The Ryzen 7 1700 with its low 65-Watt TDP appears as the real star of the Ryzen 7 models. It competes competitively with Intel's Core i7-7700K, but offers a superior performance and a modern platform in addition to a more competitive game performance. In addition, due to its comparatively low workload, the tuning potential is quite good. The Core i7-7700K and Ryzen 7 1700 are almost the same today, especially in multi-core-optimized games such as F1 2015, Crysis 3 or Battlefield 1, with 15 to 20 per cent more power .
You have also obviously missed that the Intel setup also used the SAME 2400MHZ dual ranked RAM,too so is Intel also now gimped - its stated on the graphs,they used the following:
Guess,what KL also benefits MORE from high speed RAM,so its comparatively MORE gimped.
They are not even using a Z270 board - but an older Z170. So its not even an optimised motherboard.
KL can run its IMC at a higher clockspeed anyway. PCGH have done AMD a favour here.
But thats the thing if anyone thinks they hate AMD,then LMAO.
I find it hilarious that some here were using PCGH as a gold standard when their benchmarks have made Nvidia or Intel look worse and they were fine.
Some of you have very short memories - PCGH actually were one of the first sites to push testing of "Welcome to the Jungle" in Crysis 3 which was very multi-threaded,and they painted the FX8350 in a good light. Sites like The Tech Report literally tested tunnels which made a Core i3 look competitive.
Lots of people were using this diagram they published too:
Remember that one - its been shown in many threads too regarding Ryzen.
I should know that since I started the flipping Ryzen review thread.
Many people used their tests to show that AMD CPUs could be competitive in modern games,but now the moment they show something might be not so right,the same lot jump on the same review sites.
Lets look at their R7 1700 review:
http://www.pcgameshardware.de/Ryzen...chmark-Performance-Zen-Release-Specs-1223124/
Umm?? Seems they are quite positive about Ryzen.
If the RAM was a problem,how come the internal benchmark numbers which they posted using the SAME RAM showed it doing better than an actual game scene??
Its seems suddenly many of you are trying to call out review sites when its been done before over the last 10 to 15 years,ie,optimising for benchmarks,etc or have some of you forgotten all the 3DMark "optimisations" all those years ago??
What about all the internal benchmarks for games which are not representative of what you get in game?
I bet if this was Intel or Nvidia,there would be a huge outcry if it happened.
Well in fairness that's better than or equal to what the vast majority of users are currently able to run.2400Mhz RAM on Ryzen, pathetic.
For the same reason people were recommending/buying the Pentium IV/D when they were choking on the Athlon XP/64's balls: Brand power.I still do not understand peeps recommending the 7700k for a new build even if its only for gaming.
Reviews like this to me look schizophrenic. on the one hand the are saying "its not such a bad chip and the performance is nearly there with the 7700K" while their slides say the 7700K is 40% faster, completely contradictory.
PCGH should and i think do know better, they know slow RAM greatly reduces Ryzens full potential, they are running it with very slow RAM where usually they run the RAM much faster, why the sudden change? why when it was just reviewing Intel CPU was the RAM always at least 3Ghz but now that Ryzen is in the picture wich thrives from fast RAM those CPU are now being reviewed with 2.4Ghz RAM?
There is a strange trend since Ryzen to say mildly positive things while actually engendering your testing methodology to show it in the worst possible light, no one who pays £500 for an 8 core CPU would then run their memory at a setting that strangles that CPU, stick your fingers under your Adams Apple and push, then go for a run like that, is that normal?
I think these reviewers are under pressure to do these reviews the way Intel dictate but then say something positive as a way to balance it out again, just as long as its not to upsetting to Intel.
Ryzen CPU's benefit from 3Ghz RAM, Intel CPU it doesn't make any difference, reviewers who use slow RAM against the usual grain you have to ask how legitimate they are.
I'm sorry, if i had a Ryzen CPU knowing what everyone now does i wouldn't be running it with 2.4Ghz RAM.
Its a BS review
Do you mean in gaming in general or just for this game? I've only ever seen one video comparing Kaby Lake 1080p gaming using 2400 MHz vs 3200 MHz RAM and it showed no difference whatsoever. We all know that Ryzen on the other hand does benefit, sometimes significantly, from faster RAM, mainly due to the Infinity Fabric frequency benefit.3.)Running at 2400MHZ puts Intel in a worse light NOT AMD
So what he saying here, Ryzen is crap now, dont buy it buy Intel?
Confused at the what the point is.
Jesus you dont half get angry and rant, and I still dont have any idea what your point is.
Like I said, the only one I've seen showed no difference at all in any game tested. Do you have an example or two?Look at many of the SKL/KL reviews - the IMC overclocks and faster RAM can add a decent amount of performance overall in games.
Like I said, the one only I've seen showed no difference at all in any game tested. Do you have an example or two?
