nVidia are not playing dirty their DX12 API is just a bit crap, even Intel are loosing performance because of their API.
But still with the amount of money nvidia have made you would think there DX 12 api driver would be tip top
Lets just hope Vulkan can save us all ...i am hoping so as i would love to move off MS spyware collective suite v 10 and get onto Linux for gaming or even a Vulkan win 7 too but i am sure MS will do what they can to stop that ....
I think nVidia's problem is hardware, not software, the GPU just isn't designed for it, AMD GPU's are.
possibly but wouldn't we see bigger issues in other DX12 games ..
oh..oh.. all this is getting me hyped up for Vega ..
Vulkan & Vega
MS are pushing more of their software to subs,as opposed to owned,so wait until they start pushing subs for Windows...yuck.
If things move to Linux,that is £80 saved towards a better CPU or GPU. The MS tax is just way too much if you are building a budget gaming PC. Plus it will be less faff if your drive dies,to just dl a Linux distro instead of having to re-validate your Win license,etc.
I have the same board and memory, did you try the new 1.2 Bios? I can run at 2933 without any problems at all. I tried A-XMP and it ran fine at 3200 for a couple of reboots but then it just stopped. It might be the voltage that is the problem, somebody wrote that when you use the A-XMP is sets the voltage at 1.36 and that if you set it manually back to 135 it will work properly. I haven't tested this yet.
Yes and no, not all DX12 games are created equal, some of them use A-Sync more than others, its a known fact AMD A-Sync is miles ahead of Nvidias, AMD has hardware onboard dedicated to catering for DX12, Nvidias solution is more software orientated, anyhow best not to discuss it here or you will get swamped with the GPU section guys dragging this thread down lol
Yep I've got the 1.2 BIOS, haven't delved back into memory yet, just got triple rad setup for cpu so doing some poking with that. What OC/volts are you running on CPU? And did you change the SoC volts? (which I assume is the "CPU NB VOLTAGE" option)
What board ? and what mem?
MSI Pro Carbon x370, 16gb Corsair LPX 3200 rated
Agree
Licence & now Data mining among other things is why i want to move away from MS ...for my Win 7 was the last great product by MS
This is true, Windows10 is the beginning of their backbone to pave the way for a subs based windows, it was mentioned a good few years ago this will be the last version of windows to have a moniker after it, no more win95, win10, win11 etc, from here on in its going to just be Windows, they will deliver additional features / upgrades via a paid subscription, making base windows free eventually, this does away with piracy.
Everyone gets a free copy of windows but all the real features you want a locked behind a paywall subscription method, this way they just use their existing WSUS model to push out newer windows builds with the additional features you have subbed to.
I had one of those Sandisk 480GB SSDs which suddenly went kaput last week(it seems to be a syndrome which affects them,as a mate had their one do the same).
