The AMD Driver Thread
450 games installed :eek:
Max I think I ever had installed at once is maybe 10? Lol.
They're mostly started and unfinished titles now but I did have this worry that the internet might disappear so every game I bought I downloaded and installed. I still have them all on the drives there just not installed in the PC at the moment.
The Internet may disappear? :eek:
*quickly goes to download all his steam library *
:p
I never have more than a handful of games installed at any given time. Only so many games one can play at a time, and unless one lives in the middle of nowhere, downloading does not take that long. Plus I would much rather my games run from an ssd and make use the rest of the space :)
Downloading is the main issue, I have a sub-10mbit connection so it can take a while especially if someone else is streaming video or whatever.
I uninstall games after I complete them and no longer download games by default. Seeing the post above I might consider putting most of the games I'm not planning to play in the near future on an external drive and then disconnecting that drive.
fifa still flickering with freesync enabled. i had high hopes there when i read the notes but nothing changed.
Am going to try something tonight do you leave the fifa launcher in the background? I noticed issue with fifa 17 and Freesync and it didn't used to be the case but this catched my eye. I not tried latest drivers yet
  • A small amount of apps may still experience issues with Borderless Fullscreen mode and AMD FreeSync™ technology if other applications or game launchers are running on the primary screen in the background.
no mine is super severe its absolutely unplayable because it would give u an epileptic fit. i really dont get why i cant record it, it just doesn't show on relive.
You won't be able to record display flicker with software. A phone might record it tho.
Does the flicker completely disappear if you alt-tab out and switch off Freesync?
ive just been turning off freesync since it became an issue its no biggie really but would be better if it was fixed. i did report it to amd.
I reported it other day also. It's been ages since I played fifa it was only weekend o experienced this.
This wasn't always the case though them states you see in the video all was played with freesync enabled.
This is the first time I have seen Freesync effecting the frame rate.
Any idea what to do about the error "Default Radeon WattMan settings have been restored due an unexpected system failure"?
I upgraded to the latest driver this evening...
