Literally got an email today from another retailer selling it for £280.Sub £300 6700K's don't exist either unless you buy them used. its also a dead platform.
Welcome Dice, how are you finding it?
Shout if you need any help getting the most from your new chip.
Got the latest BIOS for your motherboard?Only problem is my 3000MHz Corsair LPX will not run at anything higher than 2133 even when setting timings and volts manually.
Yes, running a 480 till Vega in my AMD box and I use 60Hz with V-Sync so as long as min fps are not too low its not a problem. I game mostly on my Intel box as it has a FuryX, when Vega drops I will use the AMD box for games though.
That looks really nice, except the green bitWell I went with the 1800X, Thought I'd support team red for a change
.Brilliant, It may just be a placebo but I swear some games "feel" smoother compared to the 5930K.
I overclocked it to 4Ghz using only 1.35v, Game and bench stable so far and using the new HWINFO which takes the 20'c offset into account the temps are amazing under a Corsair H110i GT.
I still use my 5930K as my main PC for work and its started feeling a bit sluggish, it’s not overclocked though but neither is the 1800X.Brilliant, It may just be a placebo but I swear some games "feel" smoother compared to the 5930K.
I wouldn't buy an 1800X, I went for a 1700 Ryzen. For me 16 threads is what I wanted. I'm gambling on the fact that Vulkan and DX12 moving forward will be able to leverage the performance. Should mean it will go further than the 7700k will over the next 2-4 years.
Plus.... the AM4 platform will support the next 3 generations of Ryzen so you've got an upgrade path. Where a with Intel, you buy the 7700k you don't have much to upgrade too from there without a full on board and ram replacement.
