Guys, any reason why I'm seeing slower performance, FPS in Planet Coaster?
Ryzen 1700x, 16Gb of DDR4 @ 3200 14-14-14-34 with a Geforce 960GTX 4Gb (+120 core + 160 Memory OC) Fresh install of Windows 10 with all latest drivers.
My previous rig i5 2500k @ 4.1Ghz, 12Gb of DDR3 @ 1600 with the same Geforce 960GTX 4GB (+100 core + 100 Memory OC) Windows 10.
In both screenshots I'm running the same park and on average I'm seeing around 8-10fps lower than the i5.
Seeing 8-11fps on the Ryzen
Seeing 16-25fps on the i5
Any ideas?
I got something for You to try what I'm Using. Process Lasso works fantastic with Ryzen(at lest with windows 8.1) Set game priority to High and set it to use ONLY PHYSICAL CORES. You can try To set it so it uses only 1 cpu bank also.
https://bitsum.com/
