Caporegime
- 30 Jul 2013
Wouldn't cut it for 4K though.Why not sell the titans and get one gtx 1080 ti instead?
Well I've been using it for 4k since 2015 with no issues, so.....
Anyone seen the Xbox Scorpio demo? 4K 60 FPS in Forza with a ton of room to spare all from a modified RX480 and Bulldozer CPU SoC! I'm sorry if this is trolling or fanboyish but that kind of performance makes cards like this look like dinosaurs (given what this is likely to cost).
It won't look like anything a 1080ti can run forza at now at 4k and xbox one/scopio run a very cut down version of windows 10 so doesn't need as much power. With game mode coming out forza at ultra with settings xbox will never get as they are made just for pc in horizen 3 for example.
The release of this card I totally understand.
The timing of the release I do not understand, surely the 1080ti FE would have been faster than Vega so AMD could not claim 'fastest' card status or, is it the case that Vega is in-fact quicker than a 1080ti FE which forced Nvidia to act now.
We shall find out soon enough !
Only 31.9K graphics score? Is that it..? FE 1080 Ti's are doing 32-33KFirst NVIDIA TITAN Xp benchmark result emerges
https://videocardz.com/newz/first-nvidia-titan-xp-benchmark-result-emerges
They are GeForce GTX cards though, they even have the Branding directly on them. All the Titans have been, even when they had DP compute fully enabled.
Only 31.9K graphics score? Is that it..? FE 1080 Ti's are doing 32-33K![]()
Where. The top 1080ti score here is this and it's pretty heavily overclocked.
- Score 25311, GPU 1080 Ti @2050/3054, GFX Score 30686, Physics Score 27684, Combined Score 10365, CPU 6950X @4.444, Kaapstad, Post No.1374 - Link Drivers 378.92
Fastest card here is an old Titan XP
- Score 26102, GPU TitanP @2101/2772, GFX Score 32050, Physics Score 28179, Combined Score 10431, CPU 6950X @4.444, Kaapstad, Post No.1288 - Link Drivers 376.33
. Time will tell, be surprising if Nvidia hadn't tested these to make sure they are better in all benches.Both are Kaap, btw Kaap I did love how you immediately noted you could order as many as you wanted. Time will tell, be surprising if Nvidia hadn't tested these to make sure they are better in all benches.
I'm a little tempted on this having skipped the previous and Ti... but I'd want two which sways me towards the Ti.
different CPU but the graphics score is just over 32K on this TiWhere. The top 1080ti score here is this and it's pretty heavily overclocked.
I'm just sat here wondering why my new Titan hasn't shipped yet? Anyone else received notification?
AdoredTV reckons they've got another bigger, faster Titan as well, the Titan Ultra.
I doubt they have something for now but there is always another Titan around the bend. He says it's probably not another Pascal card or Gp102 can't remember so probably Volta. I would be surprised to see a Volta Titan this side of the year but it's not impossible.
What he says is that they could make a bigger die than GP 102 on current process if needed to combat Vega, Also says it will be a crippled die and remilked full die later![]()
