- 18 May 2010
- London
Assuming you can get to 4ghz on that OC'd 1700. It isn't guaranteed.
3.8Ghz-4Ghz should be doable.
So i have been reading this thread with interest and im definitely going to get a 1700 but i really want a decent Matx mobo, are there any plans to release something like the gigabyte sniper or the asus Gene, i cant see any point in getting one of the cheaper under performing ones as i will have an upgrade path for future revisions.
Also has all the performance been gained from MS updates or do you think there is more to come, ive noticed the Mobo bios updates have made improvements (with RAM speeds) but is there going to be a 5-10% increase once the core scheduling is sorted in win10?
Honestly coming from a 3770K the doubling of cores (and higher IPC) has me actually excited for the upgrade for the first time in years, its a bit like the first time i bought a quad core.
Want something that's aesthetically pleasing, sigh!Same here, waiting on a decent mATX board.
X370 mATX instead of B350.
I suppose the assumption is that X370 boards will have better quality components also, e.g the VRMs. I haven't seen any tests yet that suggest B350 boards don't overclock as well as X370 boards but I haven't looked very hard.Fair enough. I suppose if you are going with sli you need x370. Not sure I would personally be worried about b350 spec otherwise as storage wise you run your m.2 from chip and can xfire still. Then general storage would be off chipset.
I am failing to see any difference in CPU overclocking. Most B350 boards including my own are achieving the same overclocks or even better than X boards.
Seems to hit a CPU limitation more than a motherboard limitation.
Maybe be different with RAM when boards start to support better.
64gb at 3200 is a no go at the moment whether it be 2 sticks or 4. For that size you are looking at 2666mhz. At least until may when amd release new updates for bios'sHi
All i did put this in another thread but just wondered what a few of you guys would think also
Right a bit confused at the moment
I'm looking at getting the 1700 and a Taichi board and want 32gig of ram as i use Virtual machine a lot . But it appears not all ram works and then not to the full speed was looking at something like 3200MHz Dual Channel what’s recommended without having to mess around to much with it ?
Thank you.
Whats the better board of these 4 so far:
MSI X370 GAMING PRO CARBON
ASRock AMD AM4 Ryzen X370 Gaming K4
Gigabyte AORUS AMD Ryzen AM4 AX370 GAMING K5
MSI AMD AM4 Ryzen X370 KRAIT GAMING
Any B350 ones,which are worth it. For an R5 build.
What about 32GB?
You certainly can. 2666 seems to be the most common speed. What memory are you looking at going for?Thanks for the reply seems a minefield atm with ram !
Can't really wait till may as i've got rid of my old pc ( well wil be next week )
So could i not buy 3200Mhz and run it at 2666 for the time being ?
Thanks
