You can just daisy-chain off a free port. Mine seem to work fine without any further configuration. If you want to use the TP-Link switch as well you may need to disable Spanning Tree Protocol on both devices. I did but you may not have to. You could also use a DAC cable and the SFP ports if you wanted.
They support PoE out of the box but you may need to turn it on. Certainly you need to turn on the 24V Passive option.
Guys my WiFi is unreliable and looking to get a Ubiquiti AP - my pc is hardwired so is mainly for the other half to stream netflix etc.
There's a few seconds hand ones knocking around; would these do the job or should I be looking at the lite Ac models? On cable (75mb) and have fairly thick walls living in a Victorian property. Would like to get it as cheaply as possible
Thanks
Is it possible to use the VOIP port on the USG as another LAN port does anyone know?
I did look at this as the switch I connected to the router was full, there were a few issues so I just bought a bigger switch.
https://community.ubnt.com/t5/UniFi-Routing-Switching/USG-VoIP-Port/td-p/1767161
Thanks for this, an interesting read. Think im gonna pick up a 16 port unifi switch and USG this month. Hope OCUK start selling this kit soon as well.
I have the USG and 4 AP's, I haven't bothered with the switches yet due to the cost over and above a decent gigabit switch and what I will really get out of it.
This might sound quite trivial but actually being able to see what's going on between identified wired clients and the switch port is surprisingly useful. You also get a list of wired clients by port number which makes identifying patch leads a doddle. Obviously they should all be identified at the patch panel but my installer didn't do it so now I have to do it.
I am considering buying the unifi Cloud Key, I have setup the system from my laptop at present so is it easy to move the configuration from a windows pc to the Cloud Controller Key?
Yes very easy you just backup the configuration and then import it during the CloudKey setup.
It's not really the sort of kit OcUK usually sells.
