that thing lacks ocUK sponsoringI would buy that if they made them available as a case![]()
For anyone interested, Corsair 3200Mhz 16GB working at 3200Mhz straight out of the box with XMP Profile 2 on a MSI B350 tomahawk bios 1.3!
Now to drop timings
This memory kit CMK16GX4M2B3200C16
No need to bother with the expensive G.Skill Flare stuff.
Some weird thing happening.
I flashed the new bios for the Gaming Pro Carbon X370, Set my 1800X OC, Memory speed etc.....Boot into Windows and CPU-Z shows my 1800X running at it's default speeds and even with a load on the CPU the clocks stay at their defaults.
Tried a few things but nothing seems to remedy this.
Anyone seen this before ?
Sounds like it's failed to post and the bios has defaulted the settings. This happens with an unstable oc or the infamous cold boot issue.
Try using Hwinfo and see if it reports the same things...thanks for the headsup on the new BIOS though, gonna give it a try to see if my memory issues are fixed
Well in the bios it reads the OC just fine, The rig boots just fine, Really odd issue.
HWINFO reports the same, Gonna go back to the previous bios to see if that cures it.
At 3.8 it's cold booting and rebooting fine i think i may have the worst 1700 on here :/
What volts are you at? I'm at 3.875ghz 1.425v...
I'm very confused, I'm not sure if I'm missing anything but I have the exact same DIMM on a MSI Carbon x370 and I can't even get it to be stable on desktop at 2400mhz with 1.35v and manually set 16-18-18-36. I'm also running my 1700 at 3.85ghz but I need 1.4v to do so... am I missing anything or do I just have a poor clocker and bad bios?
That official or beta bios??Well flashed back to the 1.2 MSI bios and now Windows properly registers the OC, 4025 at 1.3875, Game and bench stable.
MSI really need to properly test these updates before they put them out.
Carbon bios has not been update yet to the tomahawks, maybe the reason.
Asus are no different. The Prime B350-Plus has had six BIOS updates so far, including one for the new AGESA this week. Meanwhile, the Crosshair VI has only gotten two updates and none since late March. I guess they must be using the low end boards as a testing ground or something.MSI have got this all wrong lol. Tomahawk getting all the love where the high end are getting left behind.
Two official updates but there are others http://www.overclock.net/t/1624603/rog-crosshair-vi-overclocking-thread
