AMD RX 580 and RX 560 leak
yea but his stable clock was 1480mhz and with waterblock...AMD better release it as the same price as the 400series if not a bit cheaper.
8 Pin, wonder what others would do with 8+6, bound to be more then just the Aorus, hopefully power bug will be sorted of this method sorts it out
If Aorus is the only one to do it and hit over 1500, would have been a complete U Turn from the poor rep the G1 got
actually if i were amd i would have released this 5xx series silently so nobody would be aware of this failure lol
One thing it'll do is make reviewers test the cards, and for many large sites that means comparing against RX 480 Launch week results, and we know they did meh back then.
So if they squeezed out another 10% performance, and then thanks to relive drivers closing the 10% gap to GTX 1060, these might look like they're around 10-15% faster at least compared to launch day RX 480's.
So there's that I guess; although I agree. I don't see why they're bothering with news on the 500 line since it's just a minor refresh at most.
Ugh, how disappointing this is. I want to replace my noisy and hot R9 290 with something worthwhile, but again AMD are only offering improved performance per watt. I don't want to spend £250 to gain almost no frames, even if it will run cooler and quieter.
This is the low-mid range. You're after Vega, which is another month away at best.
AMD not filling that gap between, low-mid and high end is frustrating though. Especially now that we know they have 40 and 44CU Polaris tech, but are shoving that into the next XBOX instead.
Hopefully small Vega can manage to fill the gap between 290X/480/580 and GTX 1080.
Well, saying that the 580 will look better than it actually is, due to these sites comparing against launch day 480 performance, is a double standard though, isn't it?
It is precisely because these sites never bother to update results, that people searching for "1060 vs 480" come away with the false impression that the 1060 is faster.
So, imagine you're AMD and realise that all it takes to force these guys to update their reviews is to add 100MHz and slap a sticker on that reads 580 instead of 480... totally worth it. You have the slightly better card want people to know it.
Don't the masses deserve to know that? Me and you already know where things stand, but why should your average Joe be kept in the dark?
I agree on all your points, and sadly the industry rarely retests things; or even updates their original work if something comes along that changes it all. There's enough backlash from some reviewers when people were clamouring for them to retest Ryzen CPUs when major BIOS updates and AGESA microcode came along.
Many of the largest sites still haven't; and it's mostly been YouTubers that retested. Some very reluctantly as well.
It sucks, and it's all their to give ole Joe the impression of something new and amazing!
Look at the GTX 1060 3GB though, it was launched when the 480 and 470 were still doing meh in DX11 pre ReLive drivers, and now you rarely really see that 3GB model ever included in mainstream review sites. ( bar little youtubers like TechEpiphany )
They just list GTX 1060, so ole Joe also thinks now that the 3GB and 6GB are the same card, just half the RAM; when in fact it's cut down on CUDA cores as well.
Just like NVIDIA's recent DX12 driver claiming up to ~16% improvement; and then it turns out it was in reference to the Pascal card's launch drivers. The actual improvement was 1-2% at best.
Both sides are playing on ole Joe, and the major reviewers are all making it worse, never updating, rarely retesting, never including the full picture with notes.
As I mentioned before in the thread several times; AMD could have avoided all of this if they even just pushed out the 580 as a 40CU card with 2560 cores. They have the tech, they can make a 40 and 44 CU card with more memory bandwidth than the GTX 1080.
Yet here they are, just refreshing the current Polaris 10 line with slightly better clocks, and one can hope; better power usage.
This being frustrating is an understatement for me; especially knowing they have the technology; and whole waiting for VEGA doesn't help.
Hopefully Small Vega is fast enough to relegate the 580 to the old position of where the 380 was situated.
As crappy as it all is though, it's a refresh and I personally expect at least a 10% improvement over current RX 480's. That'll make it an okay refresh, otherwise meh. Just get a 400 card on the cheap as the price is going to drop a little with the 500 series out.
The guy was unable to increase the power limit as it was locked in the drivers. Should be a lot better once AMD releases the proper drivers with power limit slider unlocked.
All tests were performed on RX 580 clocked at 1360 MHz. Shortly put, results are comparable to RX 480 with the same frequency.
The superposition result looks very very good. I set my 480 to those claimed clock speeds for the first results (1360/2000) with +50% power limit to prevent throttling and it's about 250 points lower.
It's even better than the top score for an overclocked 480 (1425/2200) on these forums, although that was done with custom settings which are exactly the same as default 1080 extreme anyway.
Only major difference I see is the drivers, some Beta press release. Edit - It has Hynix ram while I have Samsung
Another nice performance jump coming from drivers?, is the 580 more than just a refresh? or contrary to the link they ran the test overclocked to 1480/2200?
As far as I understand it Freesync 2 support will be something AMD will enable down the stack via a driver. It's not hardware dependant.
Don't quote me on that but that's something I read a while back.
It will be interesting to compare more recent RX470 and RX480 cards to the RX570 and RX580. My Powercolor RX470 Devil 4GB can easily hit around 1.4GHZ without much tinkering for example.
