- 21 Apr 2013
Hi so I am going to be buying the parts for my new build next week and wanted to see if people thought it needed any adjustments etc.
From my old build I am keeping my Power Supply, SSD and HDD. I am going to go for a Ryzen build I think as smoothness of gameplay is more important to me than a few extra frames and I like that there is more future proof with a Ryzen build.
These are the parts I was thinking of buying...
My basket at Overclockers UK:
The parts I am keeping are..
PSU - 550W XFX PRO Core Edition 80 Plus Bronze
250GB Samsung Evo SSD
1 TB 7200 HDD.
I have a few questions when it comes to the new build.
Firstly, is everything I am thinking of picking compatible and what are your opinions? Would you change anything?
Secondly, I currently have Windows 10 installed on my SSD, will it just work in the new build or do I need to wipe the drive and do a fresh install? I'm confused on that bit. Same goes for my HDD.
Thirdly, I am thinking of just using the cooler that comes with the 1700 to start with until I can afford a decent cooler, will it be able to support an overclock?
I should add that I will at the moment be playing at 1080p 144hz, I am going to upgrade to a 1440p monitor somewhere down the line though.
Looking forward to your replies, cheers.
*UPDATE*
Due to unforseen circumstances, a simple RAM upgrade which broke my motherboard has now turned in to a fully fledged upgrade - I decided on the below:
NZXT S340 Case
Gigabyte Gaming 3 B350 Motherboard
GTX 1070 Armor
16GB 3200mhz Corsair Vengeance RAM
Ryzen 1600 CPU with Wraith Cooler.
550W XFX Pro Power Supply
250GB Samsung SSD
1TB 7200rpm Seagate HDD
AOC 144hz 1080p Monitor
You may wonder why it has took 45 pages to get to this conclusion but it's been a tough old ride full of bumps in the road. Couldn't of done it without Plec.
Cheers.
- 1 x MSI GeForce GTX 1070 ARMOR OC 8192MB GDDR5 PCI-Express Graphics Card= £389.99
- 1 x MSI B350 Tomahawk AMD B350 (Socket AM4) DDR4 ATX Motherboard= £99.95
- 1 x AMD Ryzen 7 Eight Core 1700 3.70GHz (Socket AM4) Processor - Retail= £299.99
- 1 x Corsair Vengeance LPX 16GB (2x8GB) DDR4 PC4-25600C16 3200MHz Dual Channel Kit - Black (CMK16GX4M2B32= £158.99
- 1 x NZXT Source 340 Midi-Tower Case - White Window= £66.95
1 TB 7200 HDD.
*UPDATE*
NZXT S340 Case
GTX 1070 Armor
250GB Samsung SSD
Cheers.
