- 24 Sep 2015
The 2 will be fine but the database changes that happen whern you upgrade the controller will be a lot quicker on the 3. Once you're up and running I didn't notice any difference between the 2 and 3.
I'd idtended to get a Cloud Key but decided against it, I like being able to run the bleeding edge versions of the controller which is a pain fi you're using a Cloud Key.
