- 26 Jan 2009
- Swindon, Wilts
The shutdown depends on what you have set in your power options. AFAIK, nothing's changed. Have you got it set to "energy saving" or "instant on"?
Xbox always used to do a full shutdown from holding down the Xbox button on the pad and selecting Turn off. Since the update it goes into Instant On mode. I think when I checked in the Power Options it was set to Energy Saving.
It's really odd. It was fine when the other large update happened that changed the dashboard - console would fully power down from controller however, the update yesterday has changed what its doing.. I'll double check later when I'm home from work.
Shawrey
