- 18 May 2010
- London
After such a long wait if FreeSync 2 monitors are not ready when Vega launches....
After such a long wait if FreeSync 2 monitors are not ready when Vega launches....![]()
Yeah. They are taking way to long to announce them. At this point I may just get a normal FreeSync monitor with LFC if Vega is any good. Starting to lose interest in it slowly now as what I really want is OLED with proper HDR, not none of this HDR10 crap. Just fancy something new too keep me happy for a couple of years until proper OLED monitors hit the market at a decent price that does not require KY.
I am badly in need of a new monitor... more so than a GPU to be honest. My monitors tears a lot and even causes massive hitching in BF1 because my fps are too high. I've helped matter by setting fps cap to 60 in graphics settings. But still get tearing a lot.
I got my MG278Q last year, and it's been a stellar monitor. Exact same as the ROG Swift hardware-wise; just missing the G-Sync module.
Having used both, there's a not any noticeable difference between them performance wise. Only difference for me were cosmetics ( I do love the thinner bezels on the SWIFT ), and the price.
LFC is very important though, but I can recommend normal FreeSync panels if you buy a quality one.
I am badly in need of a new monitor... more so than a GPU to be honest. My monitors tears a lot and even causes massive hitching in BF1 because my fps are too high. I've helped matters by setting fps cap to 60 in graphics settings. But still get tearing a lot.
If Vega launches minus Freesync 2 monitors... I'll be so disappointed.
The FuryX AIO is not loud even if I have it a minimum 50% fan speed with a very aggressive curve and it never exceeds 60% speed with 1180/600 overclock.
I'm not sure what Freesync 2 monitors will require that isn't already on good Freesync monitors?
As long as you buy one with LFC and a wide working range like 30-144hz or 30 to
whatever the monitors max hz rate is you've got a good Freesync monitor,
That's the main thing that's missing with a lot of early Freesync monitors.
The point of Freesync 2 should be too make sure monitor makers do not short-change us on the minimum specs,
not create a high end line of Freesync monitors and still leave those not wanting to spend hundreds of additional pounds on features like HDR and quantum dot at the mercy of the monitor makers.
Other than that I think a lot of the features mentioned such as HDR are just additional techs not actual requirements.
It'll be a shame if they are requirements because the market could still get flooded with Freesync monitors that
don't meet the most important requirements. We'd just be in the same boat.
I'm looking forward to getting some clarification on what is or isn't part of the spec.
It will then be interesting to see how prices compare to Fsync, I expect there to be a much smaller difference over time.From what I remember FS2 certified monitors will have LFC and HDR. And support the a good day range of sync.
Basically they will need to be certified by AMD to get FS2 certification.
Is HDR going to be an expensive monitor addition though?
And if it is an expensive addition does it mean there's still going to be loads of
non HDR monitors entering the market using the Freesync name that are not vetted and
controlled in anyway?
Thats true and mine the temperature rarely exceeded 55c even running full on, which makes you wonder if they overengineered it. The rad/fan was huge.
Rumoured I read was they might be a bit more expensive by the fact AMD have to certify the monitor.
Yes. But I imagine to have the FS2 logo it will have to have been validated. Otherwise it will just say Freesync.
A quick Google seems to suggest LFC and HDR.
It's a good thing. It gives you confidence. If you buy a FS2 monitor it will have support for all the basic techniques and everything is more black and white.
or manufacturers actually having to do more work to get a fully compliant Freesync 2 monitor, rather than half-assing it as so many of them do today.
the first batch was.
I seriously doubt Freesync 2 will only be used for HDR monitors. That will be very limiting.From what I remember FS2 certified monitors will have LFC and HDR. And support the a good day range of sync.
It'll be a shame if HDR adds a premium not everyone will want or can afford to pay as it will mean there's still an unregulated range of Freesync monitors. It'd be better if they made it so that any monitor made after a certain date must meet the requirements if it uses either Freesync or Freesync 2.
This is the problem they need to address for all Freesync monitors as it gives Freesync an undeserved bad name.
As i understand it FS and FS2 will co-exist. FS2 monitors will likely not cost as much as GSYNC HDR for the fact there is no dedicated hardware chip. It's unclear if AMD's certification process will cost anything ATM. Of course FS2 monitors will cost more than FS1 but like a lot of things you get what you pay for.
