Yes, I noticed this too after I tried to polish out a scratch on the screen. Some of the coating has come off where I polished.
So don't polish your screen!
Put some RainX on and it'll shed water again
There is option in settings to prevent phone from unlocking if in your pocket. Display settings -> keep phone turned off. This will switch AOD as well to save battery when in your pocket or flipped screen down.
This should fix that problem if you don't have any lock mode on.
Interested in gear vr with remote review, especially for watchimg movies etc .
They look alright
What colour did you go for?
There is a tiny bit of lip but that will settle with time, as the S7 edge one was the same.Nice! Looks very premium
I assume it's as smooth around the edges as it appears in pics? No "lip" / lifting feeling at the edges?
Does it make it any grippier?
How was it to fit mrk?There is a tiny bit of lip but that will settle with time, as the S7 edge one was the same.
Have to say I'm very disappointed in the quality of the finish on the metal trim. It marks very easily indeed. I'd much rather have bare metal for this very reason.
This is on the orchid grey so I dead to think how badly the black marks.
I did. On April 19th.
Spoke to them today and they said:
Saw something on their site about a refund if products aren't delivered within 30 days...but I imagine that goes out of the window when it's custom made maybe? But then again - aren't all of their cases custom made?
Do you have any pics?
Try dialling the below for any red tint and see if helps, just found this now:
*#15987#
This is the software fix I was laughing at earlier bud.
That's what the samsung engineer remoted onto mine and performed. after reducing red down to -6 it was still visible on my first handset.
Second one I won't even bother with as it has a charging issue also.
Both were from samsung direct. Both returned. Need to buy one from a local shop so I can return straight away. Best place to get one?
I've just checked with my local carphonewarehouse - they have stock - hope their open tomorrow
The tint is red - on my first phone it was really bad on a white screen. You could see the pinkish tint go up to the top 1.3 of the screen.
This second one has the tint on the right edge but the bottom is fine. Was prepared to live with it but charger's knackered.
I've only had two of them but both showed the tint issue. As time progresses though it either gets worse or better - not a chance I am willing to take
