My final stable overclock
1700 @ 4.0ghz @1.42v - 71c load - I could get this lower but I like silent fans.
Asus Prime Pro X370
Avexir 32gb 2400mhz
Coolermaster 240 AIO cooler.
What RAM speed on that board?
Asus Prime Pro X370
Avexir 32gb 2400mhz
I found this Posted 2 months ago , If you not seen it ,
The Silicon Lottery released their binned Ryzen CPUs today and included the following statistics in their product pages. This gives us more of an idea on the differences among the lineup in terms of overclocking potential and should help us set our expectations. AMD has clearly squeezed as many MHz out of their CPUs as the process allows.
Ryzen 7 1700
93% reach 3.8GHz @ 1.376V
70% reach 3.9GHz @ 1.408V
20% reach 4.0GHz @ 1.440V
Ryzen 7 1700X
100% reach 3.8GHz @ 1.360V
77% reach 3.9GHz @ 1.392V
33% reach 4.0GHz @ 1.424V
Ryzen 7 1800X
100% reach 3.8GHz (assumed)
97% reach 3.9GHz @ 1.376V
67% reach 4.0GHz @ 1.408V
20% reach 4.1GHz @ 1.440V
Note:
Their test setup used the Realbench stress test for 1 hour on an Asus Crosshair VI, cooled by a Corsair H105 with 2 X 8GB of 2400MHz CL15 RAM.
So really is as little of 100MHz difference in what to expect.
Woohoo! I have a top 20% 1700
I'd try pushing it higher on the crosshair, but things are just too darn temperamental still.
Yeah, I'd take those figures with a pinch of salt however. I can run realbench at 3.9 and 4.0 but its not stable in anything else
Yeah I'm slowly learning it, things are improving however ;
Not fully stable at CL14 @3500, next step 3600 CL16!
and here i am still suck on 2933mhz with samsung B die, single rank :'(
What are your other settings?
I'm 3.85ghz @1.4v
timings are 14 14 14 34 1.35v vram
soc 1.1v
i've tried dram at 1.45v and soc at 1.2v with really loose timings and still get the boot loop. only thing i haven't played with are termination voltages really.
here's a video of my bios optionsI had issues with booting into windows with any increase of the blck until I increased to PLL voltage to 1.9v.
Have you tried messing with procodt?
Looking at my bios I have a CPUVDD18 which is default 1.8v. I wonder if that is what the PLL is called in this bios?I had issues with booting into windows with any increase of the blck until I increased to PLL voltage to 1.9v.
This tells me the 1700 is still the best bet - cheaper and money difference can be put towards gpu power!I found this Posted 2 months ago , If you not seen it ,
Ryzen 7 1700
Ryzen 7 1700X
Ryzen 7 1800X
Note:
my 3.9GHz at 1.38 feels so good with low temps. Not going to loose sleep over this 4.0Ghz thingy , yet mine can but is not stable. another bios might change that. I Think anyone should be happy with the cheap 1700 doing 3.7 - 4.00. That's one hell of a c pu for the price. I might even set mine up for 3.7 and see what lower vt i can get!
