The mad dogs a cracking dripper, tip for it, build at least 3.5mm ID coils and leave the airflow wide open!
Would like to hear your thoughts on the Skywalker too!
MUST STOP READING THIS THREAD....its costing me too much money.
Heads up, tomorrow FT are running a site wide discount with code "ILOVEMOM" for 10% off![]()
First impressions:
I built the Mad Dog according to your advice - 2X 6 turns of 26/32 Kanthal clapton wire @ 3.5mm and built the Skywalker with identical coils. Both reading 0.28ohms. I've tried both with the same juice and both are thoroughly enjoyable. Both cloudy at 60 watts and great flavour. I would say the Skywalker is a bit airier than the Mad Dog - it's about as airy at 3/4 as the Mad Dog is fully open. I found the Skywalker slightly easier to build. Both look good and vape well but I'd give the edge to the Skywalker - it is easier to build, has better airflow options (it has single coil capabilty) and it also comes with a squonk pin (lookng forward to giving that a try soon).
the relevance is strong with this one!
No brainer at that price.I'll grab a Skywalker tomorrow, sounds a decent dripper, and for what it will cost tomorrow (£9) it would be rude not to![]()
Hey, if he's spending money, always good to make a saving where possible
New mod and a Skywalker for me tomorrow I reckon.
I'd actually forgot about the thing until I saw your post, when I'd last looked it was on pre-order, now showing in stock
Like the atty stand btw![]()
200w on 2 batteries isnt that realistic, but the more modern 3 and 4 battery mods are closer to it.
Personally i'd reccommend a tfv8+rx2/3 combo as from my own experience that'll give you what you want, and the rx2/3 so far has had no problems regularly chucking 150w into the troll v2 as a daily.
Be warned- smok premade coils ime have some terrible qc, if you're in any way adept at making your own then the included rba is going to be a much better experience for long lasting cloud chucking.
I'm sure pgi will be along in a bit to provide some other options.
Cheers mate, i will look into it. When i started vaping, there wasn't many VW mods and most of them were ghetto DIY jobbies/sketchy easter copies or super premium expensive things. Since i was using just a standard 18650 mechanical type mod with a dripper, fussing with coils was fairly straight forward eg. test coil/multiple coils in an ohmeter and work out what sort of current draw i will get for the sake of safety. I am not quite sure how it works with a VW mod as the power is set by the user. To get a thicker vape I used multiple coils on a sub ohm resistance but since it was single battery, i was never hitting the kind of power some of these VW mods claim to get and putting in the same sort of coil setup seems suicide.
Basically, if i can control power with these devices, what sort of total resistance am i looking for to replicate the sort of hit and vapour to my old 18650 mech mod (with a total resistance of 0.2-0.4 ohm) with maybe a bit more ohmph?
I wanted to avoid testing out loads of coils again and was thinking of just buying pre-mades but if QC is pretty bad, i'll have to get into it again.
I would like one of these beastly 150+W mods mainly for versitility but i will probably use it on the lower power end of the scale 50-100w. I do like the look of the RX2/3 you recommended, the extra battery space is a big plus. I am not into being the biggest cloud in the pub but i really enjoy the density of a really thick vape
What is a good website to buy from? ebay seems full of fakes and i dont trust it to buy batteries from.
Fogstar for batteries.
You don't need to go super sub ohm and smash 100w+ for a dense vape, most of my builds come out in the .2 - .3 range and are at their best in the 60-80w range.
The key to a dense vape IMO is tweaking airflow![]()
