Always painfulDid my old Z4's bumper that way too whilst pulling into a space
fitted new wipers, how the previous owner drove with the old ones is beyond me, difference is night and day.
You'll need to pull the scuttle panel too, 6 clips along the top edge of it quite easy to break those and the part of the scuttle panel they located into
As a noob when it comes to painting cars, how can you just paint the outside of a car and feel satisfied? Surely the colour will never match due to age (sunlight).Quick cheap freshen up on the daily hack.
New spark plugs.
Corksport stage 2 intake and turbo pipe installed.
Installed a map from accesstuner.
I hope you're just going to pay Justin for a protune and not install that Stage 1+ 98 J-Tune fakeness lolNew spark plugs.
Already spoken to Justin. New map on the cards.I hope you're just going to pay Justin for a protune and not install that Stage 1+ 98 J-Tune fakeness lol
The issue was solved by a new oring on the blow off valve.Has it solved the issues you were having?
Glad you got it sorted. What a farce!The issue was solved by a new oring on the blow off valve.![]()
