100% the drivers fault
Rule 127
A broken white line. This marks the centre of the road. When this line lengthens and the gaps shorten, it means that there is a hazard ahead. Do not cross it unless you can see the road is clear and wish to overtake or turn off.
I don't agree with the rule though in this case as the cyclist is hidden but the onus is on the driver to make sure THEIR way is clear
at the time the car turned, THEIR way was clear, the cyclist rode in to the rear side of the car when it was already mostly down the side road
Rule 127
Legally the driver is at fault, they turned across a road they couldn't see was clear and they also cut the corner of the junction because the mini bus was partly blocking the junction both of which are against the highway code.
Avoidable on the cyclists part, should really be filtering much slower and down the middle of the road.
On that basis 33/66 (bike/car).
I'm a road cyclist. Cyclist is a complete fool, undertaking at what looks like considerable speed in a hazardous situation.
Unfortunately some cyclists place way too much emphasis on conservative of momentum, sometimes at cost like this.
The cyclists is actually on the OTHER side of the broken white line or at least cutting it very very fine, so is potentially crossing the road at speed. He is not on the road that the van is, because he is being a ***** and trying to undertake everyone by going up on the pavement and bombing it across the minor road instead.
Stop the video at 11 seconds and you will see.
Cyclist for sure, just bombing across a road like that with no vision.
Equally applies to the car.
But that doesn't give the motorist the right to hit him...
Pretty unfortunate for the motorist as they had zero chance of seeing that coming.
Except you shouldn't have to anticipate some numb entitled prat watchj traffic around him stop and not realise why and do the same.
