Mine still won't boot at 3200, just throws up an f9 error and boot loops, so annoying.
Upgraded to F4D. I am able to set the memory strap to 3333Mhz no problem, anything above this and system will not load no matter how loose the timings or the voltage. Memory is G-Skill Trident Z RGB 3600 CL16. Using BCLK and memory strap 3333 I have got up to DDR4 3430 at CL14 (haven't tested higher yet). So far I would say F4D is going in the right direction
Are there any other notable changes
Can you sync the motherboard lighting to your memory and GPU like with the Asus Aura software?
Hello, yes you can, just use the new software.
Hello all,
I know there as a lot of new BETA BIOS now due to the new AGESA 1006 code, this code and lots of tweaks for memory are on out official forums. We will have a new retail BIOS very soon for these boards.
Do you have any ETA on the first stable (non-beta) BIOS using AGESA 1006?
I'm happy running F3 for now as I'm managing 3.9 GHz on an R7 1700 with 2933 MHz RAM. But looking to up the RAM to 3200 MHz, its full spec, when I can.
RGB FUSION,What is the name of the software?
No confirmed date yet, however we have now uploaded many of the new BETA BIOS to our website after testing, you can down load the F4D now as at adds a lot of fixes for memory speeds.
http://download.gigabyte.eu/FileList/BIOS/mb_bios_ga-ax370-gaming-k7_f4d.zip
