What tools do I need to service spd pedals? The pedals on my commuter are creaking like hell so I think it's time to take them to bits and regrease them.
Different models need different tools, which model?
Yeah I think that's it - when it comes to climbing much of the effort is overcome by technique, rhythm and leg speed/feel of certain power levels. I find as as soon as I'm adjusting that technique, like leg speed, it's immediately becomes 'harder' due to the lack of a rhythmic pace that I'm 'used to' riding at.Ha. This can be hard to match someone else's pace on a hill. Much easier often to just plod along at your pace when it gets steep. I was trying to hang behind a mate to get some video footage up hill 14 the other day but in the end I said screw it this is hurting my legs too much and upped the cadence to get to the top.
Would've given them a try, but not in white! That's your trademark!See how you find the Aeron UV Arm Sleeve, they come up a little on the shorter side I've found but might be too thin for what you're after. They keep the wind chill down and enough warmth in on cold starts at the upper end of single degrees to low double digits and cloudy.
I don't tend to wear long sleeves and can't start to - running out of room in my cycling wardrobe! I probably have over 20 SS jerseys... May give the DHB merino ones a try. It's either them or the Castelli Thermoflex. Thanks for the Bt'win recommendation Chris but don't think I want their logo on any of my kit, I'm a bit of a snobSomething Merino usually work well in both cooler and warmer temps. To be honest when it is that warm I'll put them on to warm up with and then whack them off, if not I'd be wearing long sleeves anyway.
Ride the Giant. To me it seems silly to jump straight in to riding the Trek hard in a track session when the fit isn't even right yet. You'll spend most of the session fiddling and tweaking things rather than spending the time concentrating on what you're there for and riding hard.Picked up my new bike (Emonda S5) earlier this week but I've only ridden it around 40 foot so far, and I have a track session tonight. Not sure whether to go with the Giant just for tonight, or just jump in feet first and take the Emonda, I could probably iron out any fitment issues during water breaks. I was hoping to get a few miles in on the Trek just to get comfortable with it but my wife has been poorly so there's just not been the time.
I really need to sell the Giant to fill some of the financial hole the Trek has just created, but it's just so damn comfy and easy to ride I'm half wondering whether to keep it as a commuter/winter bike.
M520.Different models need different tools, which model?
That logo is so small you could just put it on the underside of your arm or colour it in with a marker penI don't tend to wear long sleeves and can't start to - running out of room in my cycling wardrobe! I probably have over 20 SS jerseys... May give the DHB merino ones a try. It's either them or the Castelli Thermoflex. Thanks for the Bt'win recommendation Chris but don't think I want their logo on any of my kit, I'm a bit of a snob![]()
Bt'win shorts tend to be my go to for shorter rides. Can't fault them for the £15-20 they cost.
The m520 needs a specific plastic tool to open the plastic part but it's often seized in and breaks instead of coming out. A lot of folk treat them.as disposable for that reasonM520.
Balls.The m520 needs a specific plastic tool to open the plastic part but it's often seized in and breaks instead of coming out. A lot of folk treat them.as disposable for that reason
I sometimes wear black socks with white shoes. Come at me bro.Important post. I would like to apologise in advance for my wearing of white socks and black shoes. I'm not sure what came over me with said sock purchase as I don't own any white shoes.
I would like to use the excuse of them still having black bands at the top, along with a fluo strip which matches my shorts & jersey, while also wearing a white helmet.
Yup from what i.recall you can open 540 with a cone spannerBalls.
My other option is to replace them with m540s, given that they are a bit more hardwearing and less likely to rust. Are they any more serviceable?
Was a hilly one so glad we did Streatley first. It was bugging me that I didn't finish the segment properly last time so now I have a time that I can use as a baseline to measure improvements going forward.Balls.
I'd rather service things than chuck them if possible! I think I'll replace them with 540s, though, as they'll rust less and by the looks of it they're easier to dismantle and fix.M520s are only £20 on CRC - is it worth the agro servicing them? I've just searched my mailbox and found an order some 520s from 2006 (they were £21.99) and are still on one of my MTBs. The 520s on my road bike are 7 years old this year.
Cheers, that looks helpful and looks like I can apply it to 520s or 540s, whatever I end up with.Any use?
to me it seems silly to jump straight in to riding the Trek hard in a track session when the fit isn't even right yet. You'll spend most of the session fiddling and tweaking things rather than spending the time concentrating on what you're there for and riding hard.![]()
but the Fulcrum wheels are a little bit flexy - which ones would be best? Stiff and heavy or light and flexy?
