Here's mine. Settled on 3.95ghz 3333c14 and about 63c under load.
Excuse the poor photos and background![]()
so whats the fan setup like, im assuming the radiator fans and bottom are in and the others out ?
@ Ste, where did you get your Thermaltake Water AM4 mounting bracket from? You using one for an Asetek?
Yeah it's from corsair for their H110i. Same bracket. Thermaltake wanted stupid money for delivery and all the asetek outsourcers (corsair, NZXT, thermaltake) use the same bracket.
Is that standard copper pipes?
Could anyone using the GSkill Trident Z RGB 3600Mhz CL16 sticks share their SPD data? Appears that using Aura software has corrupted my SPD data and i need a copy to reflash.
You can extract the SPD data using this tool. http://www.overclock.net/t/1624603/rog-crosshair-vi-overclocking-thread/14260_20#post_26083280
This thread is missing some ryzen pics. Thanks Ste for reigniting it.
Have you tried typhoon burner?
I have the c17 version assume that is no good?
When the SPD corrupts can you still boot manually setting timings? Might back mine up...
