Personalize your very own Xbox Wireless Controller with Xbox Design Lab. Start from scratch or customize an existing design online, choosing from a wide range of color combinations. Further express yourself with metallic finishes, rubberized diamond grip, and laser engraving for a more personal touch. You design it. We build it. With Xbox Design Lab, the next Xbox controller is truly in your hands. Now available in US, Canada, UK, France, and Germany.
Hopefully its not really loud or something... I've heard a few people say their PS4 Pros are noisy when things get instense.
So who thinks Sony will reveal the PS5 later today.....![]()
I'm very happy with price of £450, will pre order once available.
this console aimed at myself who spent £120 on elite Pad, just want something thats true 4k on OLED screen![]()
Erm..I would VERY much like to see the tower only ( which is a huge liberty to remove from expenses), at those prices for components thats built to the same spec and close to the finished form factor.
And Live is what..about £30 a year shopping around, so you can even have 5 years of that and Add £150 to that budget.
I just added it up with parts I can buy new right now for £530. Including an 8GB RX580, 8gb RAM, G3258, matx board, 500w PSU, 1TB SSD and Matx form factor case.
That could be reduced with used parts if so required by the user.
I don't know why you are so offended? I am not going against the Scorpio/consoles in anyway. I use them myself. I also understand pc's are not for everyone as well. Just simply stating it can be done for a very similar price range.
An RX580 manages 15fps in Ghost Recon Wildlands at 4k. I bet Xbox one x does a bit better...
No idea why it needs to be compared to pcs all the time. It's a games console...
You cant build a 4K gaming Pc for anywhere near the price of an Xbox One X. Looks like a nice bit of kit.![]()
Someone should give it a go to spec it.
Bluray drive
PSU
Mobo
12G DDR5
Similar CPU
Similar GFX
Before you think about a small case
Fans
Controller
OS
Assembly time
