Tower block fire - london
I know and understand exactly what you are saying. But social media, tv company's and any other media has no place speculating on something of this scale before any forensic teams have even been into the building. It's of no use to anyone other than the ratings.
I hope to god..............if he exists................that peeps will be jailed for this. But as i said earlier.................big money talks and the peeps will walk.
Read both my posts, the comment you have quoted was in response to the potential for this to all be swept under the carpet.
My previous post makes clear my opinion on the BBC's ill advised panorama last night and the rest of the 24/7 news circus that is on going.
Not a reasonable comparison. The method of construction (And what it was trying to achieve) were totally different.
WTC was a structuaral steel building aimed at providing large, essentially single room, floors. To the extent that there was a cost failing it was that the architects failed to ensure a structurally robust and fireproof wall around the building central core (Stairwells and lift shafts) IIRC the stair wells were only surrounded by dry wall, reasonably fireproof but totally inadequate in the event of any sort of explosion.
But then, nobody anticipated a fire fed by hundreds of tons of aviation fuel... :(
WTC would have likely survived any "Normal" fire just fine.
Grenfell Tower was intended to provide lots of small rooms on each floor. from what I have gleaned, it was constructed using "In Situ Concrete" IE the main structure is essentially a single casting of steel reinforced concrete (Like Petronas Towers).
This sort of structure is essentially fireproof and will withstand very high temperatures without structural failure (As it clearly has done!)
The issue wasn't the building, it was was clearly what it was recently wrapped in.
AFAIAC this isnt a "Blame" thing, I am a bit Japanese about this. There is a problem here that needs to be resolved. It is likely that there are many other tower blocks that have been recently refurbished using similar materials.
THESE BUILDINGS CANNOT BE CONSIDERED SAFE!
There is a potentially massive and expensive problem to solve here and I really do not want resources wasted on trying to find people to blame...
Just now, If I was somebody who lived in one of these recently refurbished tower blocks I would be currently feeling very uncomfortable about going to sleep in my home.
I want every current resource put in to making very large numbers of people safe. The Lawyers can haggle over the corpses later... :(
Come on, politicians and enquiries is always about blame to save their own incompetent behinds.
I'd tend to agree therr. As much as everyone wants to blame people sometimes things just aren't anticipated and/or unintentional overlooked. Sometimes "**** happens" unfortunately.
If the building code was followed then it's the code that's at fault - in which case why was the code deficient? It sounds like the government were warned about it a few times recently, but they can't just update planning immediately and/or backdate planning code to older already approved construction. Perhaps this was just terribly unfortunate timing?
If planning wasn't followed correctly then why? Was it a failure of the architect? If so why did they spec the wrong stuff (and why was it approved by the planning department)? Were they leaned on for cost cutting or did they miss something?
Did the contractors install the incorrect cladding? (I don't believe that's the case.)
If everyone was doing everything correctly and this was just a horrendous accident then no one is really to blame. I'm sure in that instance there would be uproar, but that's life unfortunately. Alternatively there could be serious deficiencies in the planning department or the architects office and in which case people could well end up getting jailed for negligence.
What certainly needs to be done is to look at all the similar buildings that have recently been renovated and do either preemptive emergency changes, or wait until the inquest has concluded and make modifications if needed then. Let's learn from our mistakes and make sure the same thing doesn't happen again.
^does seem pretty suspect that in this day and age(stuff was installed 2016) with all the PC's and H&S such a catastrophic error could be made. Soon find out I guess.
I think it's typical of society these days with rules taking precident over common sense, the idea that one rule fits every single situation. The rule will get amended until the next incident where it doesn't work and it will have to be changed again. We need to teach people to think for themselves and not just follow rules like robots.
In such a fire the first priority should have been total evacuation and worry about extinguishing the fire later.
With only one staircase they'd struggle to get firefighters up at the same time as getting people down, it would have been chaos. If things operated as they should, the fire should have essentially been contained so there'd have been no need to evacuate people. As it is, it spread very quickly and in ways not foreseen; that was the problem.
Also, I'm not sure how you'd have been able to get people out in time. By the time you'd have known what was going on or that you needed to get people out the building was impassable due to smoke and fire.
It's a whole cocktail of problems and it's not as simple as just saying people should have been evacuated.
Fire retardant cladding is not a planning issue, its a Building Regulations issue.
http://www.lbc.co.uk/news/london/we...renfell-tower-refurbishment-was-not-approved/
Could get pretty messy, looks as though they might have just gone ahead and done the work, without any approvals, inspections or official sign off from anybody.... If true, I'd expect lengthy jail terms for those involved.
Seems to me they were issued a completion certificate under an initial notice, so they wouldn't have had a full plans approval, doesn't seem fishy at all.
"The formal signing off of the work was provided by a completion certificate and not by a full plans decision notice, which was not required in this case. The system status “Not approved” appears because a decision notice was not issued. However, a completion certificate was issued signing off the works under the Building Regulations."
I can imagine there is going to be a lot of finger pointing and ass covering going on for some time
And, as I said last night, this is entirely the wrong approach. Corbyn should wind his neck in and stop inciting people to riot. This is a nationwide issue affecting many councils around the country (And I dare say Many of them will be Labour controlled councils rather than Tory ones)
I was think of an analogy this morning.
If Grenfell Tower was an aircraft, the whole fleet would likly be grounded pending the accident investigation.
In an ideal world ALL similarly refurbished tower blocks should be immediately evacuated pending surveys to determine the safety of the new cladding.
This really is an accident that could happen again later this afternoon! The fire was triggered by a faulty fridge. We are in the middle of the hottest June in 40 years. All such equipment will be working flat out and I dare say that when we look at the sort of fridges/freezer that people will have in Council flats it is more likely to be Beko than Meile!:eek:
And no, I really do not think I am overreacting...
Promised myself i'd steer clear from this thread, but... i have a beko :|
Struggling to understand why people are saying the Fire Brigade should have exotic equipment for a situation that simply should not have happened - the cladding has allowed the fire to spread around the outside of the building - this in itself is a catastrophic failure of the refurbishment. Never ever should this material have been fitted. Secondly, the initial fire should have been confined to the flat - some sources are saying the initial fire was actual extuinguished within the flat but it had spread outside - again - should never have happened. Finally, the corridors and especially the staircase should never have filled with the smoke that did. The entire refurbishment appears to have failed in such a way that an impossible fire happened. I understand a "40 pump" fire has occurred 3 times in my lifetime - once in the 70s, once a waste fire that threatened the olympics so wouldn't normally require that much resources, and Grenfell.
If people had done their jobs it simply would have been a small flat fire and nothing more.
Regardless of regulations - regulations can fail even with the best of intentions - its ridiculous they aren't better prepared for tower block fires in a part of the country with a relatively higher density of them. It should have been "impossible" but you can't bank on impossible when the potential situation is foreseeable.
Because this type of fire is impossible to fight. And because it should not happen. The rules are already in place, they were not followed, the proposed work not checked and the finished work not checked properly. Simple (?) gross negligence at so many levels.
