Caporegime
- 8 Jul 2003
- In a house
I remember when Nvidia did vacuum cleaners.
AMD announces Radeon Instinct MI25 specifications
https://videocardz.com/70440/amd-announces-radeon-instinct-mi25-specifications
That vid above, never gets old!![]()
As other have noted it's 'passively cooled' in a server with industrial fans blowing air over it. I would guess the reason for the length is just be for the heat sink, though obviously we can't tell without opening it up.One of the advantages of HBM is supposed to be a small PCB yet this card measures up at 10.5", the same as a lot of NVidia GDDR5X equipped cards.
300W TDP and its Passively Cooled, something does not add up here.
No OS Support for Windows
What on earth is going on here?
AMD seem to have got something very wrong here, lets hope the other Vega cards are a bit better.
It's a server card.
The Vega GPUs will have 16 GB of HBM2 memory on the interposer, and interestingly, have dedicated NVM-Express ports that will allow for 2 TB of flash capacity to be directly attached to the GPU accelerator to extend that memory size; think of it as a fast cache for the GPU memory.
I had one of those! Wasn't that bad, remember playing lots of WolfET on an FX5800U
The GTX480 though that thing was loud and hot... the 3870X2 was also a noisy bugger!
Depth might be the factor they avoid more then length I'd guess. I've been in the big server room for my local authority years back, there is a constant roar of massive fans filling the room and the air is far cooler then any normal environment its not built to be occupied by anything but these great behemoth machines stacked up with cables and racks of gear. It's great on a hot day like but pretty unpleasant just to stand there a few minutes otherwise. I believe in some hashing operations they run a special chemical made by 3m over the cards, not heard of anyone in a bedroom operation or garage even doing such things because its probably dangerous.As other have noted it's 'passively cooled' in a server with industrial fans blowing air over it. I would guess the reason for the length is just be for the heat sink, though obviously we can't tell without opening it up.
It's a server card.
I remember when Nvidia did vacuum cleaners.![]()
What point is there using HBM2 when it runs slower than current NVidia cards like the Titan Xp.
HBM2 is lower latency, has more memory channels and takes up far less space and power for the amount of storage you get.
So bandwidth is no longer a selling point of HBM2
Having said that NVidia cards with HBM2 have much higher bandwidth.
You trying to tell me this is Not the gentlest and most soothing sounds you've ever heard?
Reminds me my old 290X Crossfire setup![]()
You had to hear the old crossfire x1900s. Oh man.
i miss that game![]()
NVIDIA cards have 3-4 HBM2 modules, Vega has two modules.
What is the spec on this new AMD card, 2 x 8gb modules?
It isn't quite how I remember it. Looks very blocky now...
Not that the rest were hugely better but that is one of the poorer maps for visuals the beach especially looks quite basic compared to today's graphics.
I remember it looking better than that back in 2003 - 4?
