Don't know! Let us know what you find out!Just ordered one from htc does anyone know if they come with the new foam as standard now?
Ok I will be the guinea pig.Don't know! Let us know what you find out!![]()
How would you know?Ok I will be the guinea pig.![]()
How would you know?
Like I said, mine is fine, so it could have just been a bad batch? But arranged another, it cost me nowt so rude not to.
Easy as pie fella.Got mine today used it for 5 minutes rubbed the foam at the back of the strap and it left black powdery residue on my finger, so will ask HTC for some new foam. The good news is that the strap itself is very comfortable it takes the pressure off your face. Not sure it's worth £99 though £50-£60 would be more like it.
-take a pic of the serial on your Vives box.
-download a copy or scan/snap of your invoice for the deluxe audio strap.
-go to live chat: https://www.vive.com/uk/support/contactus/
Tell them you need a replacement foam and upload those two documents.
Confirm your address.
Had mine over a week from a shop in Bolton.
Foam fine on mine but getting a replacement sent since they are free, only took 5mins via HTC chat to arrange.
Yes, yes it is. No fiddling with ear/headphones either.
is it a lot easier to adjust and put on vs the older one?
yes easy to adjust but you do that the once for yourself then thats it.
My housemate literally can't get the normal vive to fit on his head. He's either extremely incompetent or has a funny shaped head, I can't work it out.
Has it got stops that you can set it to? So I am 2 stops in and he is 3 stops in or whatever
Like GBRusty said, the mic is built into the Vive HMD so still the same and it is pretty poor tbh. I did make a DIY pop filter for it with a bit of sock and electrical tape, which does help a bit.What is the mic like though?
Why are you not using the Velcro tie to centre it?There is still pressure the front (there has to be, otherwise it would flop around), but it's more of an even pressure compared to the old strap, and not as much of it. Much much better IMO.
My only complaint would be the cable running to the side - it's become even more of an annoyance than before. I keep wondering what that is touching me on my shoulder. It also ends up considerably more twisted than the previous arrangement. Wireless...where are you??
