Thanks, didn't realise the filter didn't star it outHowling, edit and delete sweary before a mod spots it.
It kept giving me flashbacks of the Doctor in Smokey and the Bandit.
Captain chaos to the rescueSacrilege!!!!!!!!!!!!!!! It's Cannonball Run![]()
That threw me a bit too
I'm not sure where the FE sits really. You could probably buy the Radeon RX Vega AND WX 7100 for the price of the Frontier Edition, or a little less.
AMD were competitive with Nvidia at the high end until they decided to forfeit and give the title squarely.to Nvidia, so.a bit of a shame if they can't come back to the same back park performance.It is vaguely reminiscent of the ryzen hype with amd using blender as a benchmark. Ryzen is a bit behind intel in gaming but its a drastic step up from where they were.
Seeing as how 14LPP is targeted at 3 GHz, and 7nm-LP (leading performance) is targeted at 5 GHz, things could be pretty interesting with Zen2.
Problem is GF don't seem quite as competitive even using the same node as other foundries - AMD may need to go elsewhere to be truly competitive again :s
I'm just a little worried AMD have made no progress on efficiency. The water cooled FE really does seem to require 375w. The FiryX required 250w and is clocked 50% slower on a process that should required circa 50% more power clock for clock. That is a big step backwards. Even if we use the 300w figure this is still a step backwards: 20% more power to run 50% Higher clocks on a process that should reduce power about 50%. Now I know AMD had to add a lot of logic to help Vega achieve real world performance closer to the theoretical instead of just brute-force compute power,but if that has ended up.costing them.more power than it's saved it seems futile.
Yeah that's on the 14/16nm generation, but the 7nm generation looks to be quite a different story.
It's looking quite solid at this point that GloFo will actually have the best-of-the-best 7nm process. TSMC are starting with a low-power one because of Apple, and Samsung are slightly behind, and doing weird stuff by pursuing 7, 8, and 6nm simultaneously.
And Intel are just working on highly maturing their 10nm.
Also PCPer Pre-ordered BOTH Frontier Edition cards! Expect reviews!
Unfortunately, no, we were not provided with pre-release samples. But we're ordering both cards so we'll have them when they're released for testing and review.
Getting his Burt Reynolds movies mixed up!Sacrilege!!!!!!!!!!!!!!! It's Cannonball Run![]()
