- 13 Apr 2013
- Scunthorpe
You are just like me overthinking everything. I would love to have the Asus Strix boards, apparently the are very good but not in stock.Yea the way I saw it was, sure a b350 board may well do zen+ fine but you know you'd have that niggle, that gnawing feeling that you just aren't getting the most out of the next gen chip due to board limitations (even if that's not the case!!) but spend too much eg CH6 and you're possibly in the realms or either buyer remorse (shouldn't have spent so much on my mobo boo hoo) or you think well I've spent 'X' amount on my board and chip its damn well gonna last me!! (Yes I have a complicated mind lol!!!)
Yea, overthinking everything is the bane of my life!!You are just like me overthinking everything. I would love to have the Asus Strix boards, apparently the are very good but not in stock.
Was the R5 1600 compatible with board out of the box?Yea, overthinking everything is the bane of my life!!
The strix boards nearly caused me to delay my purchases even further. Was finally set on the gaming 5, then saw the strix and thought they looked great. But it was the gigabyte support that won over for me in the end.
i would have imagined so. would be awkward if it wasnt as the board as far as i know is not backwards compatibleWas the R5 1600 compatible with board out of the box?
Systems not fully built as I'm watercooling but I did stick a spare gpu in to test the hardware and was able to get straight into bios to flash it to the latest version without any issues.Was the R5 1600 compatible with board out of the box?
Looks good Supra!
I have a question; are the temperatures that AMD Ryzen Master give accurate? I have a R7 1700 with the stock cooler and I'd like to try overclock it just a touch but it already hovers around 45 degrees just doing mundane tasks.
, certainly not anything made by AMD. Some of the new board BIOS are sorting that out but if you dont have an x chip it should be ok I thought... But I didnt believe most of them anyway until proper version of AIDA64. That said, expect them to get hot 30-35 idle and who knows under load depending on your cooling situation.Looks good Supra!
On Asus Crosshair VI Hero setting Sense MI Skew: Disabled in UEFI options gains me what I deem as correct temps.
Indeed, I've also disabled this.
Hi gavin, I'd not noticed issues but have one as my windows drive. Will install later and report back.
My board soft bricked itself this morning. Which I only discovered after assuming the PSU was dead and swapping it out. Ugh. Losing patience!
