Arguing one way or the other about the RX gaming performance with a card that is not even intended for gaming is premature, to insist on using the FE results as indicative of the RX gaming performance is a huge gamble, what if these results turn not to be indicative of the RX performance at all?
Suddenly you look like a ####, same goes for a lot of reviewers who currently gamble their reputation like this, PcPer.
Vega RX has at best the same GPU as Vega FE.
Vega RX has at best the same type of memory as Vega FE.
Vega RX has at best the same amount of memory as Vega FE.
Vega FE has what are stated to be gaming-specific drivers.
It's not a huge gamble to use the FE performance as being indicative of RX performance because it's fundamentally the same card. If RX differs in hardware from FE, then RX will be worse than FE because it has to be much cheaper.
It might previously have been theoretically possible that RX would use GPU and memory clocked significantly higher than FE, but the power requirement and heat generation of FE cards completely rules that out.
So any increase in performance would be down to an extra month's development on the drivers that have already been in developement for at least a year. It's...optimistic...to think that will make a huge difference to performance.
It comes down to this - if AMD does have something much better than Vega FE, why did they release Vega FE as the halo version at >£1000 a card?
or it could be theres great variation across Vega models. Since we know of Vega on APU, its the latter I take as the more likely outcome.
