True. But you just know some cry baby somewhere would kick up a fuss. So it's probably easier/safer for them to leave it as an opt in as opposed to opt function.Surely they could just add it to the Steam T&C's, there's no personal data involved, simply taking hardware specs doesn't even have to be user identifiable.
If you do that, you're just using the Windows Balance Profile and will lose the performance enhancements gained from the Ryzen Power Profile.
Sense MI handles clock frequency and as long as you have C states enabled in the bios, the CPU cores will downclock and go to sleep where applicable. I apprecaite that software indicates the CPU is stuck at the highest frequency, but that's because it can only read the last P state the processor was in.
Using the Ryzen profile and PState overclock mine shows the downclocks, in some programs. Aida works but not core temp sits at the top freq).
Seems to work the same with High Perfrormance plan and settings 20% minimum processor.
What exactly are the benefits of the Ryzen profile?
Does this looks ok for R5 1600 processors, i have run cinebench R15 at stock boosting steed of 3.4Ghz and there score was 1140? Memory set to 2933Mhz.
So they are gaining between 3 - 4 percent per quarter which isn't bad. TR launch will prolly accelerate that a little bit moreWith over a week of data, I think the Passmark chart has settled enough to see how Ryzen is doing in Q3 so far for Passmark submissions.
https://www.cpubenchmark.net/market_share.html
As of now AMD share has gone from
18.1% in Q1 to
20.2% in Q2 to
23.8% in Q3 (so far).
Pretty good momentum. Just keep in mind Ryzen chips are more likely to be benchmarked right now. Steam Hardware Survey (a more reliable indicator of processors in actual usage) still not showing an uptick. I suspect it will only increase once Raven Ridge comes out as Intel still dominate laptops.
http://store.steampowered.com/hwsurvey/processormfg/
What's the reasonable & obtainable overclock for R5 1600, would that be around 3.8Ghz?
People are getting over 4ghz with them.Well my one might be a dud, set up the ration to 36 with 2933 Mhz ram, and when I load the HW monitor the cpu is set to 1550Mhz. What might be the issue? R15 score drops from 1140 to 4131600 chips seem to be clocking higher than 1700. I'd be hoping for closer to 4ghz.
But 3.8ghz is a pretty safe overclock with close to stock voltage.
Well my one might be a dud, set up the ration to 36 with 2933 Mhz ram, and when I load the HW monitor the cpu is set to 1550Mhz. What might be the issue? R15 score drops from 1140 to 413![]()
. Ordered 16 gigs corsair lpx 3200 ddr4 which is what i have in my main system hopefully works fine in this. Also hope that gigabyte have some updated bios for the ga-ab350m for better ram speeds.I have not seen many people use samsung e die, but there are plenty of hynix users out there that have managed 3200mhz. I think you'd have better luck getting hynix to work than e die purely because of its popularity and the amount of guides out there for hynix.Which memory would achieve higher clocks, corsair plx with Samsung e die, or Hynix one
.Yours will be the faster one right? Can't have the missus having a system as good or faster than yours![]()
. Mine will be upgraded to Vega/1080/Ti and she will keep my 390X as she games at 1080p and I game at 1440p.
